Webcam snapshot and printed information for Print-Report
My 3D printers contain automated bed emptying solutions. The beds are being emptied after a print is completed and is initiated from the END_PRINT macro. I am relying on my print reports to verify whether a print is successful or failed. Unfortunately the webcam snapshot in the print report always shows an empty bed as the snapshot is taken after the beds are being emptied. Is there a way to call out the function for these snapshots which I can put in my END_PRINT macro? Or is there another way to solve this?
My second question is, is there a way to customize the information that is listed on the print reports? For example, I don't really care about the achieved temperature precision and the long text below it. I also would like to customize the Event Notes at the bottom to list more user understandable error messages, like: Emergency pressed, Filament runout, Filament Jam, etc.
Best regards, Faris (Felix / LFT / Insolution)
@writeReport Message
Write a message to the print report with timestamp if reporting is enabled.
Regarding snapshots I see the problem. Belt printers might also have same issue, so having a custom command to trigger the image would be a good idea and if it was not triggered we still can make one like we do now. Will put it on my todo list for improvements.
Best regard, Faris (Felix / LFT / Insolution)
@makereportsnapshot
that when it is called makes a snapshot for the report. If such a snapshot exists it is used instead of making one at the end, so just put it where everything is fine and it should work.
Only thing is I'm not sure if it is already in stable versions. So just try if it works otherwise it will work after next update.
I noticed that feedback is not optimal in case it does not grab the image you get no feedback, so for 1.5.0 I will add some response to log.
Would it be possible to call it from within my END_PRINT macro for example?
https://imgur.com/a/CXOXsn8
I am starting to believe it is not implemented yet in our version of Repetier Server.
