Version 92.6, pushing Encoder with SparkLCD does not work any more
I did some modifications to my sparkcube printer and after that tried to update the firmware. I used the configuration.h from version 92.2 to create new firmware with the configuration tool. Everything works except the pushing of the encoder. Dialing the encoder works, but pushing it does nothing at all. Encoder and Display by the sparklab.
#define UI_ENCODER_CLICK 37
defines the pin. It is the second after the 4 pin header if you check the pin layout of radds. Have no pinout from the lcd but since these values came from vincent directly I guess they are correct. So maybe a hardware defect? Have you checked with multimeter between gnd and 37 (gnd is just before 37) if hitting the button closes circuit? Maybe also only a bad solder.
