What's the most key point when you decide to get a 3d printer
As the title said, what's the key point when you want to get your first 3d printer? Speed or others?
  • I would say Design is first then consider,
    Design type delta Corexy other Cartesian
    what do you intend to print? (how big will you need the Bed)
    material i.e Filament what type will you print (will you need a heated bed?)
    Building your own or buying a pre-built design
    speed is a kin to size in some regards Most 3D printers are dependent on carriage design
    Most can print a large item in under an hour or several hours depends on many factors.
  • Your intended use is crucial when selecting a 3D printer. For optimal results, take into account print quality, compatibility of materials, build volume, user-friendliness, software support, and continuing maintenance expenses.
  • Knowing your unique requirements, such as print size, material compatibility, and usability, is crucial when selecting a 3D printer. Dependability and community support were my top priorities. Troubleshooting can be greatly aided by a strong support system. For long-term use, take into account firmware support such as Repetier and upcoming updates.
