Printing hangs in 1.5.0
Hi there,
I tried the DEV version 1.5.0 in anticipation of my Bambulab x1c. I have two other klipper printers configured, running fine in 1.14.8. After upgrading to 1.5.0 I can still move the axis, calibrate, etc, but when I start a print, the printer hangs, repetier server hangs and can only be revived with a sudo reboot from console.
  • When did you test this. Will test as well to rule out a new deadlock with current version, but 1.5 is dev so it changes and can contain bugs and there werse in deed some deadlocks with new stuff I already fixed.
  • I downloaded the dev version on January 2. unfortunately I did not check any logfiles or console outputs by the time. The print stalled upon hitting print... I heated up, but it never actually started printing.
  • As I received my bambulab X1 Carbon printer, would you rather recommend the most recent nightly version?
  • Nightly version is 1.4.18 not 1.5.0 so will not work for x1c. Printing without ams mapping works already fine for X1C with dev, just need to check now klipper - hope it happens to me as well. Sometimes these hangs are timing dependent. Will at least test it with a few prints so I can check where it happens.
  • I could upgrade to 1.5.0 again and try to reproduce it. Just need to know which outputs you need to debug. I will be able to do it on Friday as I am on a business trip ;-)
  • I hope to get it by then, but if not what I need is a list of backtraces as described here:
    especially output from
    thread apply all bt 20
    this shows where server is completely hanging. Unfortunately without lines but normally I find it knowing at least the function where it happens.
  • Good news, I could find the dead lock myself and it should now work.
    great!! I will try it out tomorrow and let you know!
  • I still have odd behaviour. I didn't try printing with my already configured klipper printer, but I do get undervoltage messages and reboots when I tried to change display settings. Never had this happened before. But I will do a flow calibration today on that printer with 1.5.0 and see how it goes.
  • printing works now.... so that seems to befinde
