Printing hangs in 1.5.0
Hi there,
I tried the DEV version 1.5.0 in anticipation of my Bambulab x1c. I have two other klipper printers configured, running fine in 1.14.8. After upgrading to 1.5.0 I can still move the axis, calibrate, etc, but when I start a print, the printer hangs, repetier server hangs and can only be revived with a sudo reboot from console.
  • When did you test this. Will test as well to rule out a new deadlock with current version, but 1.5 is dev so it changes and can contain bugs and there werse in deed some deadlocks with new stuff I already fixed.
  • I downloaded the dev version on January 2. unfortunately I did not check any logfiles or console outputs by the time. The print stalled upon hitting print... I heated up, but it never actually started printing.
  • As I received my bambulab X1 Carbon printer, would you rather recommend the most recent nightly version?
  • Nightly version is 1.4.18 not 1.5.0 so will not work for x1c. Printing without ams mapping works already fine for X1C with dev, just need to check now klipper - hope it happens to me as well. Sometimes these hangs are timing dependent. Will at least test it with a few prints so I can check where it happens.
  • I could upgrade to 1.5.0 again and try to reproduce it. Just need to know which outputs you need to debug. I will be able to do it on Friday as I am on a business trip ;-)
  • I hope to get it by then, but if not what I need is a list of backtraces as described here:
    https://www.repetier-server.com/knowledgebase/debugging-crashes-hangs-on-linux/
    especially output from
    thread apply all bt 20
    this shows where server is completely hanging. Unfortunately without lines but normally I find it knowing at least the function where it happens.
