Cant Connect from external device
Hi, This might just be me, but repetier server while running on Windows runs fine for a day or two, and loses its HTTPS certificate. After this, I can not connect from IP:3344 anymore even after resetting the web certificate. I'm not sure if I'm doing something wrong or if my installation just keeps on getting corrupted. Any advise would be greatly apreciated.
3345 has a self signed certificate if you installed it but that requires a correct date so it is in valid time slot when validity is tested.
