Cant Connect from external device
Hi, This might just be me, but repetier server while running on Windows runs fine for a day or two, and loses its HTTPS certificate. After this, I can not connect from IP:3344 anymore even after resetting the web certificate. I'm not sure if I'm doing something wrong or if my installation just keeps on getting corrupted. Any advise would be greatly apreciated.
  • Port 3344 is http, so where comes the certificate from you are using?
    3345 has a self signed certificate if you installed it but that requires a correct date so it is in valid time slot when validity is tested.
  • Okay, that makes sense, I was making a HTTPS certificate as I couldn't access the HTTP 3344 site. I'm not sure why I'm losing access to 3344. I'll have to check my systems some more, thank you.
  • See global settings->Webserver there you can make a native https certificate and enable https for  Repetier-Server directly. Only problem is that it is normally in a local network so it can only create self signed certificates on it's own. But you can also upload an existing certificate.
