Repetier 232 does not work on k/Ubuntu 24.04
Repetier 2.3.2 AppImage works perfectly on Kubuntu 22.04, but it is impossible to get it to work on Kubuntu 24.04. The AppImage file generates a lot of errors in the console related to GDI+ and doesn't start at all. When trying the tarball, even after installing the Mono libraries, the application launches with a glitched and unusable GUI. Kubuntu 22.04, every time I start it up, shows a countdown (currently 282 days) until the distribution stops receiving updates. I would like to ask the developers to provide a solution to make the AppImage work... perhaps by producing an updated version of the AppImage file, as it is likely outdated and no longer compatible with the latest distributions. Thank you.
