Help with Z-probe in Repetier firmware
hi. I just dont understand the instructions on how to get this working. I have a custom CoreXY and there very little information regarding this for this type of printer configuration.
I have manually leveled the nozzle against the bed by just being able to slide a piece of paper.
At that point Prove is triggered ( also min hardware endstop is connected but not triggered since is a little higher )
Then i home all and issue command for probing. Prove high in firmware is set to 1mm
is the above corect? After this now what?
Whats that about not using min endstop and using max endstop? its a little impractical in a CoreXY.
CAn anyone point me to the correct proces?
I have a good level on the bed.
What I don't understand is the procedure itself on what the correct distance the sensor should be and how to set that up
Rises the bed until the nozzle touched the plate. At that point I was 6.6mm from Zmin. I placed that number as Z probe high. Then runed G32 S1 and it gave me the matrix which gave me all number none of the 0 or 1.i assume that is bad?
Is this correct?
On another note why does it lower the bed after it does G32? Is that correct? Is there a way not to do it?
may I place a question, please: You just said that with G32 S2 it's not necessary to do Bed leveling before every print (that's logical to me). Now people tell me that a Z homing overwrites bed leveling (which seems implausible to me). That's why I do the G28 X Y/G32 thing in the Start script for every print, which is a PITA because of the long time it takes. But I get better Z=0 values with that. Still the bed-nozzle distance is different with every new G32, I suspect I still lose steps (although I'm at Z max feedrate/homing Feedrate = 3) or my sensor is crap.
Can you confirm bed leveling and the Z axis length measured in the G32 process are still active/used/taken into account after homing? So I can bed level every once in a while and just have G28 in my start scripts?
