Strange letters on display.
Hi, Bought me a DUE/RADDS +Radds display . (12 &10 pin) Installed 1.04 firmware. Display have just funny karacters that make no sense. Not because of cables. Just the wrong letters. Installed with english in meny. Anybody ??
Sounds like it gets data wrong and result is garbish. Only english letters are supported anyway. Make sure cable is ok and does not go close to heater/motor cables which can disturb display. Also try hitting reset after first start to see if it improves when it initalizes display with power active for a while.
In case of 128x64 pixel it can also be a wrong driver which does not match the chip.
It is the 20x4 display. Radds display in the menu. Cables ok. Can see letters but they give no meaning.
There are 4 lines.
After reset top line is for a brief moment "5gpgtggr 1.0.4"
4 line "urgntgr rggdy" meaning "printer ready" ??
you see for radds display there are already some longer delays (10us instead of 2us). I think you need to increase this to make it stable. My guess is that 10us is still to slow for your board while it worked on mine. It could also be an other delay that is too fast but start with the 10us delay..
I try this, have never edited anything. I am more off a hardware man. I will report back.
Hi
Tried a delay off 25us. not better .Now I notised 2 errors. Been there all time I think.
If I compile again, device is found.
Tried to double the delay on some lines. Not working. Do not know witch ones to delay..
I belived that chosing in firmware menu should be easy
My bad.
Worked with 10 cm long cables. Have just tried the RADDS + display on the desk. Not in a printer. Thr funny letters was with 50 cm cables, Worked also with 12 pin 10 cm and 10 pin 50 cm. Not with 12 pin 50 cm, 12 pin had continuity on all pins. OK, continuie trying.
