Amf with modifiers not previewing properly in host.
I am attempting to use modifiers in slic3r to change infill pattern/density for sections of a single object.
I have made the necessary changes in slic3r and exported everything as an amf.
When I import the amf to repetier host both the model and lambda modifier show in the same group, positioned correctly but when I the slice with slic3r in host the preview only shows the model infill without the modifiers infill.
Any ideas what I'm missing?
So does that mean that if I load any amf file that host will generate a new amf? Why does host generate a new one? When I load the amf exported from slic3r, host does recognise the shapes of the model and the modifier.
Should I export the combined model and modifiers as gcode from slic3r instead? I had avoided that since host cant render a preview based on gcode.
