How to read a power loss pin in firmware?
I have tried Repetier-Server Rescue mode. It doesn't seem to be able to detect power outages immediately. After I cutted down the power of printer, I found the server still sending commands to the printer. So I try to use a extra power monitoring module for 3D Printer to do that.
https://usa.banggood.com/Dlion-5V-UPS-Power-Monitoring-Module-For-3D-Printer-Part-p-1354115.html
It has two signal pins. One pin is power loss output singal, another on is input single to control power. Can Repetier firmware read this power loss signal and tell the Repetier Server? How to configure? Thanks for help.
That is all related to power loss detection. Important for server is that HOST_RESCUE is set to 1.
