FLSUN SR filament sensor - usable with Repetier Server?
Does anyone use FLSUN SR with Repetier Server and has the filament runout sensor working? I tried to look into it and it seems to me that I actually need to use another firmware than stock. I tried filament replacement manually - hit the pause print, the head goes nicely away from the object, replace the filament, hit continue and that's it. The only thing is I had to sit at the printer at the correct time.
I can see the status of the filament sensor (1 or 0) when I ask for the printer status (do not remember the g-code now). But if I understand it correctly, the printer should be sending some message automatically (it does not seem so). Is there a workaround asking for the status of the switch? It is pretty close to the extruder, so it would have to be like every second line and that does not feel right.
The firmware is based on Marlin and there should be source code available. How would one enable the filament sensor sending a message to the serial port?
If a pause event is hit, will it send a message through Repetier Informer? Is it possible to set it like that?
There was no notice of the printer doing an M600 in the log (should it be there?) Is there anything I can do about this?
Would M108 make it continue? If so you could add a parser for it and send there
M108
@outOfFilament
and trigger the server internal handling which now can execute moves beause M108 did make it continue. Just a try, nut sure if it directly triggers pause again.
Is there any option to pause when this happens and send a message to the Informer? That should take care of this for this printer without modifying the FW.
