Printing does not resume
After updating to version 1.4.13 I cannot resume printing after pausing.
I have my printers with a filament sensor connected to the GPIO of an RPi. This sends a pause and filament change command.
This works, but after changing the filament, I press the resume button and nothing happens.
The pause command and the sensors have been working for a long time, the problem started after updating to the latest version
Problem is a bug on our side that was introduced when we tried to prevent pause during pause. That made it impossible to continue when you are in cooled down state. So in that version you must comment out @pauseExtruderCooldown with two ;; until you update to 1.4.14.
Since you use a pi you can also run
installDev
if it is a newer image to install dev version where it was fixed already.
