Can NO limit switches connect to power? Instead of ground?
Using Mega board and ramps 1.4
I wired up my limit switches to power on one side, and the signal pin on the other.
Can I pull the sense pins low, and have them activate on a high signal?
Is there a way to change that in the firmware?
Or would I be better off to just rewire them?
Thanks,
Bryan P
Thanks,
Bryan P
However, I don't even know where to begin to find the code that controls this, I don't think it's set up to be changed easily.
Thanks,
Bryan
