Server to server + Master panel
Hello R,
It's becoming hard to connect printers to same server on USB, is it in any way possible for 2 server instances to work together?
Preferably we would like the same interface as we have now, just that some of the printers are on one server and some are on another server and connected and managed on one interface.
Kind regards.
Kind regards.
Repetier monitor does not have the abiliti to run/edit or add projects
BTW: In Monitor you can open server gui without logging in from any printer, so anything missing there is available with opening the regular gui from monitor.
also normaly USB can only be splitted 256 times, with this i would make it limiteless.
