It has a smallish SSD so I want to ONLY put programs on it, and put all the files, images, movies and more over on a larger (and slower) 2TB internal hard drive.
for location depending on os and how to change where Repetier-Server looks for it. On unix systems you can also make a link from /var/lib/Repetier-Server to your new destination.
Ok, sorry.... I looked and on my Win11 system and I could not find the config file or anything that look familiar after reading the article.
I Installed Repetier Server, and then stopped the service. I was then going to edit the Config file to Point to the Storage drive, but couldn't find anything that looked right, and then restart the Server.
For a default install, one instance, can you tell me what file I need to edit. I want to point it to "D:\Repetier"
What I have is C:/Program Files/Repetier-Server/ and then bin, extra, firmware, etc...
What file in What folder should I be editing.
Sorry for being so dense... Win11 is giving me fits as it looks and behaves differently than Win10...
You should create C:\Program Files (x86)\Repetier-Server/bin/RepetierServer-extra.xml with a copy of C:\Program Files (x86)\Repetier-Server/bin/RepetierServer.xml and just modify
Just note you need to edit at some other place, because the files are not writeable by you and only when you copy them you get a question if you are sure and then copy works.
Locations of file folders are typically assigned during the installation or configuration of software. For Windows, "C:\Program Files" or "C:\Users[Username]" are frequently the default locations. These can be altered during setup or in the application's settings. Check the documentation or configuration file for the precise path settings for custom software.
https://www.repetier-server.com/startup-configuration/
with a copy of
and just modify
to
