Pause Button
I know that this 3d printing thing is supposed to be automated, and you should be able to walk away and let it go. So I don't know if I'm doing something wrong, or if it's just this finicky for everyone, but I keep having instances where the print head crashes into some part - especially support material or a feature being built up from support from a point, like a cone shape, and the edges curl up (how do I stop that???), but it crashes into it and knocks it off. I then pause the print, hot glue it back down, and hope for the best.
The problem is that going through the menus is such a cumbersome way to get to the pause, especially when you need to stop it NOW. Without having programmed for Arduino before (or in C++ for that matter - that is what it is coded in, right?), how would I go about programming for an external "Pause" button (added hardware button, of course)?
