Can I add a feature to the firmware to send a message when motors have stopped?
I am using your firmware in a cartesian configuration on an Arduino Mega to move a camera to collect images.
I would like to modify the firmware so that when all motors reach their commanded position after a G code move command, the firmware will send a "done" message, then I will know I can capture an image.
I cannot quite figure out where in your code to put this.
I am communicating to your firmware from a custom python script.
Thank you,
John
Thank you,
John
M400
will wait for end of moves. So send M400 followed by
M118 Snapshot
M118 will print message on communication channel. As you see no firmware modification needed to achieve this.
I would appreciate any comments regarding if this might create unexpected problems?
case 380: // M380 Print done at end of all moves
Only thing to consider is that if you then start sending new commands camera will move again so either make it wait for done before moving again or add a delay to make the snapshot.
