Spool Weight Display
Hi, I now have a weighing scale on each printer that measures the weight of the spool and thus determines the remaining filament. I use this value for planning which print is still possible on which printer. In addition, of course, the colour and the material so that the weighed result is also correct.
Since I schedule my prints via Repetier, it would be great if I could see this information somehow in the interface. The scale is based on ESP32 and therefore I can transfer the data to the Repetier via Rest, MQTT or otherwise.
At the moment I simply don't have a "place" where I can write this information to the printer.
@set global.spoolWeight {{http_get("http:/...")}}
And use the variable in the dialog to include the weight. Then you have either a wizard or new command that runs the script and shows result. You can even do some computations convertig it for different densities.
The ESP weight scale can send the information of the weight to an endpoint in repetier and then it can be used for an computed expression? Or do I need to save it somewhere to request it like described in your post?
It would be perfect to have an API where I can just save simple "key-value" pairs to use them in the computed expressions.
My solution uses other way - it calls the esp web api only when required and stores result. If it has multiple values use json format. computed expressions can extract values from json strings easily.
In both solutions you need the dialog to show it and a call from user who wants to see it.
@set global.spoolHeight 70
or so then you can use value in dialogs any time. 5-10 minutes frequency is ok. Only thing is you need to wait after bootup for first push message.
