Uploading by drag on "Upload G-Code" gives error "size exceeded" when trying to print
Since version 1.4.3 when dragging a gcode file on "Upload G-Code" it stated that the size would not fit on the printer like:
Print Printer
200.00..300.00 200.00..220.00
but prints fine when ignored. The size of the part to print is not that large anyway.
The warning is not shown, when dragging the file on "Direct Print".
Slicer is Cura 5.2.
Print Printer
Slicer is Cura 5.2.
Typical reasons are:
- Prime line at negative y like prusa does. Often reachable but bed is defined to start at y=0 and not y=-3.
- G28 assumes a different relative/absolute mode then printer does. Add a G20 or G21 directly after G28 depending what it should be. This is often in end gcode when there is a G28 and then you add a move to a different position.
- Of course the obvious that the object is placed outside bed, but when you say it was small and print worked I assume one of the 2 above.
Print Printer
So why is there a 300?
and why does it not happen, when dragging the same gcode file on "Direct Print"?
G1 X0 Y300 F1000 ; prepare for part removal
in the end
But all my gcodes hav this Y300. It looks like the older repetier-server (do not know exactly from which version I updaetd) did not throw this warning message...>
Thanks for support!
