com port not detected
Hello, I have looked and looked and can not find a resolution to my issue. I have a Davinci 2.0 running latest Repetier firmware, a Windows 8.1 laptop and a Beagle bone black rev c (Debian 8) wifi setup.
I am trying to connect to the printer using Windows installation of Repetier Server.
My steps are to ssh into BBB, start the server and attempt to add the printer. RS will not see my printers com port which is com3 and the baud rate set to autodetect. I have tried setting separate baud rates as well with no luck. The printer is connected to the BBB via a usb hub. Any assistance is greatly appreciated.
Thank you for the quick response. I am a newb as you can tell. I had read that the structure that I should use for Linux is
" COM3= /dev/ttyS2 or /dev/ttyUSB2 or /dev/ttyACM2" I tried all 3 with no success before my original post. I suspect that it is the format I am writing it for Debian 8 Jessie?
Thank you for that. I did try the drop down and there is nothing there. I think when I get home I will connect the BBB directly to my computer and the printer and see if I can get what I need that way. Will let you know. By the way, I am up to date on the required files so I don't believe that's the issue.
Thank you again for taking the time to advise.
