Unable to upload gcode from Prusa to Repetier OEM
I'm sure this is probably not your problem but maybe someone has a solution. The Prusa slicer allows uploading gcodes to the Repetier Server. But will not allow uploading to the OEM version of Repetier Server. It gives an error "Mismatched type of print host."
So only solution until then would be to comment the oem branding name in the RepetierServer.xml file where it gets set, then slicer will accept it.
