CoreXY moved endstops 24.5mm on X and Y Min endstop bounce and Jitter
Just installed a new J end mount
for My e3d hot end this cause a bit of an issue as the new part cooling blowers
are almost an inch in front of the end stops (i.e. never gets close) Moved
X and Y end stops farther out by 24.5mm back and over (left side and rear) normally
homing is XYZ on this CoreXY
Now when I manually Home X or Y it comes up to the
end stop and bounces, then jitters
if I move manually before power on set the
carriage into the x and y stop are on and lighted home and it goes
up to Z end stop
if I move, say 190 X and Y and 100 down on Z and
if I choose to go home it goes to the end stop Y and then X jitters from left
end (hard to tell if it actually get to Y but X moves right instead of left (end
stop to about 100 and jitters never goes left to the X end stop, forcing me to
do a hard power off
I checked the end stop with m119 all low and
go high when Held, so the end stops work and the motors X and Y move when
commanded with g1 x 190 Etc.
Wondering if there is something simple I missed
when moving to the new end stop. Are they not static position? Do I need home X and
Y manually and save the new home positions? (acts like it wants to go farther than the end
stop? since the new zero is 24.5mm away for x and y)
Nothing has been touched in the Config file, only moved physically the X & Y end stops 24.5mm, very strange. Any help or suggestions are welcome. Certain I am over thinking something?
Repetier 0,92 CoreXY 600x600x900 3 z motors I X 1
Y and 6 extruders ramps 1.4 (Soon changing MKS L version 2)
Recoush
went back and pulled the X & Y reprap switches , at first i thought i had a corrosion problem was just very dirty and found the copper exsposéd the other one looked OK replaced the switches
Installed a new optical sensor For the Y axis, Attached a target to the carriage rather then having it hit a switch, The new optical switch is a open is high / Low signal
The X axis is same reprap end stop with Led as before., added a target to the carrier since they don't align.
Looking at Y axis with a new optical style sensor (open is High and Closed is Low)
need to reverse, at Configuration h
endstop pullup_y min true
endstop Y_min_inverting true (change this to false?) In my case for the COrexy
minhardware _endstop_y true
this was the only change for the one Optical sensor, been a while since i had to update anything in the Configuration files. Ran complier then upload ran the home button, smooth and silky no more bounce or jitters, guess the dirty switch was the issue
I only use the endstop min for XYZ
and only other endstop max is Z stop Max way down at 690mm just in case something goes very wrong
thanks you
Recoush
