After Repetier-Server update to 1.4.2, Repetier-Server Monitor 1.4.4 progress bars doesn't work.
Progress bars on Repetier-Server Monitor shows 0.0% and doesn't update. It works fine with earlier Repetier-Server 1.4.1
  • Ok could reproduce it. Internally line counter does not get increased which then prevents updating the job progress seen in monior. Monitor uses a different solution then regular gui which is why I did not notice it. Will fix it for next server release, but this has no negative impact on stability or quality. Just optical that the info does not get updated.
