Disable local GUI on Tochscreen temporarily
after an apt dist-upgrade my raspberry lost its network config, so I cannot access config by SSH.
As it has a touchscreen attached, it boots into Repetier GUI and I could not find out, how to disable this GUI in order to start a terminal session on the touchscreen to fix network.
I tried commenting out "chromium-browser --noerrdialogs...." from “/home/pi/.config/openbox/autostart", but then the screen remains blank.
At least on current image Ctrl+Alt+T opens a terminal on screen.
As with all linux systems Ctrl+Alt+F1-F7 switches between virtual consoles. F1 is invisible and F3 or F7 are graphic console. But others should show a regular terminal.
