The button connect to printer does not work
Hello,
I have already checked othe discussions in the forum but no problem seems to be similar to myne
I am trying to connect my 3D printer My Creator 2 to the program Repetier-Host version 2.2.4
I am using an AppImage running only once, i.e. by the SW Repetier-Host-x86_64-2.2.4.AppImage.
The button "connect to printer" does not work, I have tried to change some com parameters, but no change.
The USB is connected to the printer by /dev/ttyUSB0, bit rate 250000 and so on.
All other commands of the GUI work well, only this button shows some problem
Do I have to install the AppImage SW definetely on PC or something else?
In the past I had no problem to connect the Repetier-Host to the printer, I used the version 2.0.5 but not the AppImage version...
many thanks in advance for some feddback
Federico
You can also try to switch printer to 115200 so it uses a ansi baud rate that c# can handle it self.
Other solution which is also better is to install Repetier-Server and connect printer over that. In host you then use Repetier-Server Connector instead of serial connector to connect. The server also has no issues with 250000 baud and you can even close host while printing and printing still continues.
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
LD_LIBRARY_PATH = /tmp/.mount_RepetiI01vSs/usr/lib:
MONO_PATH = /tmp/.mount_RepetiI01vSs/usr/lib
Could not set X locale modifiers
Gtk-Message: 11:13:12.576: Failed to load module "canberra-gtk-module"
at System.IO.Ports.SerialPortStream.ThrowIOException () [0x0000f] in <9c6e2cb7ddd8473fa420642ddcf7ce48>:0
at System.IO.Ports.SerialPortStream..ctor (System.String portName, System.Int32 baudRate, System.Int32 dataBits, System.IO.Ports.Parity parity, System.IO.Ports.StopBits stopBits, System.Boolean dtrEnable, System.Boolean rtsEnable, System.IO.Ports.Handshake handshake, System.Int32 readTimeout, System.Int32 writeTimeout, System.Int32 readBufferSize, System.Int32 writeBufferSize) [0x0001b] in <9c6e2cb7ddd8473fa420642ddcf7ce48>:0
at (wrapper remoting-invoke-with-check) System.IO.Ports.SerialPortStream..ctor(string,int,int,System.IO.Ports.Parity,System.IO.Ports.StopBits,bool,bool,System.IO.Ports.Handshake,int,int,int,int)
at System.IO.Ports.SerialPort.Open () [0x0006f] in <9c6e2cb7ddd8473fa420642ddcf7ce48>:0
at RepetierHost.model.ProtectedSerialPort.Open () [0x00035] in <63c553364181423faf81fbf20d6b440d>:0
at (wrapper remoting-invoke-with-check) RepetierHost.model.ProtectedSerialPort.Open()
at RepetierHost.connector.SerialConnector.Connect (System.Boolean failSilent) [0x00208] in <63c553364181423faf81fbf20d6b440d>:0
The serial ports belog to group dialout, but apperently the user running the host does not. So that is a simple issue as it seems. You need to add group "dialout" to your user.
