Temperature graph for 2nd extruder
Hello
First of all thank you for your great programs. I'm using host and firmware and I plan to setup a rPI with server too. So.. Great work!
I just finished building my 2 extruders printer and.. I noticed that the temperature graph inside repetier host shows only the temperature of the first one (it detects, however, that there are two extruders and lets me view and set the temperatures for both).
Can you add the second extruder to the graph?
Thank you
It could use the same scale/graph area as the first extruder, as the ranges are likely to be similar.
