Klipper
I have installed Kliper on R-S, it is connected, than I was coping configuration from newest klipper running machine ... first problem was that it is not recognized Generic temperature sensor, I have chcnged it to ntc ... it is working, but second problem is with heater_bed control section. I dont know why it is not correct control: pid
How can I check version of klipper?
Make sure to compile a new printer firmware from the installed sources. Version mismatch might cause this.
Version is the one you installed 0.10 or latest master which is constantly changing. If unsure or if you want to update you can uninstall and install klipper. This does not delete the configs, just reinstalls the klipper sources/dependencies.
