Klipper
I have installed Kliper on R-S, it is connected, than I was coping configuration from newest klipper running machine ... first problem was that it is not recognized Generic temperature sensor, I have chcnged it to ntc ... it is working, but second problem is with heater_bed control section. I dont know why it is not correct control: pid
How can I check version of klipper?
  • sensor_type: Generic 3950 to sensor_type: NTC 100K beta 3950
  • edited August 2022
    And now MCU Protocol error .. I am tired .... :#
  • > And now MCU Protocol error ..
    Make sure to compile a new printer firmware from the installed sources. Version mismatch might cause this.
    Version is the one you installed 0.10 or latest master which is constantly changing. If unsure or if you want to update you can uninstall and install klipper. This does not delete the configs, just reinstalls the klipper sources/dependencies.
  • restart_method: command is not working too, what is the right command?
    reinstalled, but restart_command: command is not working
  • uploadet firware using R-S, still not working. Connected to old paspi with pure clipper and it is working without problems. I do not understand it ...
  • # This is the default configuration for the printer: Voron350R1
    # This option is needed if you want to use the recover feature so that Repetier-Server can manually set the z position in Klipper
    [force_move]
    enable_force_move: true
    # This file contains common pin mappings for the BigTreeTech Octopus V1.
    # To use this config, the firmware should be compiled for the STM32F446 with a "32KiB bootloader"
    # Enable "extra low-level configuration options" and select the "12MHz crystal" as clock reference
    # after running "make", copy the generated "klipper/out/klipper.bin" file to a
    # file named "firmware.bin" on an SD card and then restart the OctoPus with that SD card.
    # See docs/Config_Reference.md for a description of parameters.
    ## Voron Design VORON2 250/300/350mm BigTreeTech OctoPus V1 TMC2209 UART config
    ## *** THINGS TO CHANGE/CHECK: ***
    ## MCU paths                            [mcu] section
    ## Thermistor types                     [extruder] and [heater_bed] sections - See 'sensor types' list at end of file
    ## Z Endstop Switch location            [safe_z_home] section
    ## Homing end position                  [gcode_macro G32] section
    ## Z Endstop Switch  offset for Z0      [stepper_z] section
    ## Probe points                         [quad_gantry_level] section
    ## Min & Max gantry corner postions     [quad_gantry_level] section
    ## PID tune                             [extruder] and [heater_bed] sections
    ## Probe pin                            [probe] section
    ## Fine tune E steps                    [extruder] section
    [mcu]
    ##  Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
    serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_3A0033000250534E4E303720-if00
    [mcu rpi]
    serial: /tmp/klipper_host_mcu
    [adxl345]
    cs_pin: rpi:None
    [resonance_tester]
    accel_chip: adxl345
    probe_points:
        175, 175, 100  # an example
    [virtual_sdcard]
    path: ~/gcode_files
    #[include kiauh_macros.cfg]
    [pause_resume]
    [display_status]
    [printer]
    kinematics: corexy
    max_velocity: 300
    max_accel: 3000             #Max 4000
    max_z_velocity: 15          #Max 15 for 12V TMC Drivers, can increase for 24V
    max_z_accel: 350
    square_corner_velocity: 5.0
    #   X/Y Stepper Settings
    ##  B Stepper - Left
    ##  Connected to MOTOR_0
    ##  Endstop connected to DIAG_0
    [stepper_x]
    step_pin: PF13
    dir_pin: PF12
    enable_pin: !PF14
    rotation_distance: 40
    microsteps: 32
    full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
    endstop_pin: PG6
    position_min: 0
    ##  Uncomment below for 250mm build
    #position_endstop: 250
    #position_max: 250
    ##  Uncomment for 300mm build
    #position_endstop: 300
    #position_max: 300
    ## Uncomment for 350mm build
    position_endstop: 350
    position_max: 350
    homing_speed: 25   #Max 100
    homing_retract_dist: 5
    homing_positive_dir: true
    ##  Make sure to update below for your relevant driver (2208 or 2209)
    [tmc2209 stepper_x]
    uart_pin: PC4
    interpolate: false
    run_current: 0.8
    sense_resistor: 0.110
    stealthchop_threshold: 0
    ##  A Stepper - Right
    ##  Connected to MOTOR_1
    ##  Endstop connected to DIAG_1
    [stepper_y]
    step_pin: PG0
    dir_pin: PG1
    enable_pin: !PF15
    microsteps: 32
    endstop_pin: PG9
    position_min: 0
    position_endstop: 355
    position_max: 355
    [tmc2209 stepper_y]
    uart_pin: PD11
    interpolate: false
    run_current: 0.8
    #   Z Stepper Settings
    ## Z0 Stepper - Front Left
    ##  Connected to MOTOR_2
    ##  Endstop connected to DIAG_2
    [stepper_z]
    step_pin: PF11
    dir_pin: PG3
    enable_pin: !PG5
    gear_ratio: 80:16
    microsteps: 32
    endstop_pin: PG10
    ##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
    ##  (+) value = endstop above Z0, (-) value = endstop below
    ##  Increasing position_endstop brings nozzle closer to the bed
    ##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
    position_endstop: -0.5
    #position_max: 230
    ##  Uncomment below for 300mm build
    #position_max: 280
    ##  Uncomment below for 350mm build
    position_max: 330
    position_min: -5
    homing_speed: 8
    second_homing_speed: 3
    homing_retract_dist: 3
    [tmc2209 stepper_z]
    uart_pin: PC6
    interpolate: false
    run_current: 0.8
    ##  Z1 Stepper - Rear Left
    ##  Connected to MOTOR_3
    [stepper_z1]
    step_pin: PG4
    dir_pin: !PC1
    enable_pin: !PA0
    gear_ratio: 80:16
    microsteps: 32
    [tmc2209 stepper_z1]
    uart_pin: PC7
    interpolate: false
    run_current: 0.8
    ##  Z2 Stepper - Rear Right
    ##  Connected to MOTOR_4
    [stepper_z2]
    step_pin: PF9
    dir_pin: PF10
    enable_pin: !PG2
    gear_ratio: 80:16
    microsteps: 32
    [tmc2209 stepper_z2]
    uart_pin: PF2
    interpolate: false
    run_current: 0.8
    ##  Z3 Stepper - Front Right
    ##  Connected to MOTOR_5
    [stepper_z3]
    step_pin: PC13
    dir_pin: !PF0
    enable_pin: !PF1
    gear_ratio: 80:16
    microsteps: 32
    [tmc2209 stepper_z3]
    uart_pin: PE4
    interpolate: false
    run_current: 0.8
    #   Extruder
    ##  Connected to MOTOR_6
    ##  Heater - HE0
    ##  Thermistor - T0
    [extruder]
    step_pin: PE2
    dir_pin: PE3
    enable_pin: !PD4
    ##  Update value below when you perform extruder calibration
    ##  If you ask for 100mm of filament, but in reality it is 98mm:
    ##  rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
    ##  22.6789511 is a good starting point
    rotation_distance: 23.1098511709 #22.6789511   #Bondtech 5mm Drive Gears
    ##  Update Gear Ratio depending on your Extruder Type
    ##  Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
    ##  Use 80:20 for M4, M3.1
    gear_ratio: 50:17               #BMG Gear Ratio
    microsteps: 32
    full_steps_per_rotation: 200    #200 for 1.8 degree, 400 for 0.9 degree
    nozzle_diameter: 0.400
    filament_diameter: 1.75
    heater_pin: PA2
    ##  Validate the following thermistor type to make sure it is correct
    sensor_type: ATC Semitec 104GT-2
    sensor_pin: PF4
    min_temp: 10
    max_temp: 270
    max_power: 1.0
    min_extrude_temp: 170
    control = pid
    pid_kp = 26.213
    pid_ki = 1.304
    pid_kd = 131.721
    ##  Try to keep pressure_advance below 1.0
    pressure_advance: 0.045
    ##  Default is 0.040, leave stock
    #pressure_advance_smooth_time: 0.040
    ##  E0 on MOTOR6
    [tmc2209 extruder]
    uart_pin: PE1
    interpolate: false
    run_current: 0.5
    [firmware_retraction]
    retract_length: 1.1
    retract_speed: 25
    unretract_extra_length: 0
    unretract_speed: 25
    #   Bed Heater
    [heater_bed]
    ##  SSR Pin - HE1
    ##  Thermistor - TB
    ##  Uncomment the following line if using the default SSR wiring from the docs site
    heater_pin: PA3
    ##  Other wiring guides may use BED_OUT to control the SSR. Uncomment the following line for those cases
    #heater_pin: PA1
    sensor_type: NTC 100K beta 3950 #Generic 3950
    sensor_pin: PF3
    ##  Adjust Max Power so your heater doesn't warp your bed. Rule of thumb is 0.4 watts / cm^2 .
    max_power: 0.6
    min_temp: 0
    max_temp: 120
    control: pid
    pid_kp: 58.437
    pid_ki: 2.347
    pid_kd: 363.769
    #   Probe
    [probe]
    ##  Inductive Probe
    ##  This probe is not used for Z height, only Quad Gantry Leveling
    ## Select the probe port by type:
    ## For the PROBE port. Will not work with Diode. May need pull-up resistor from signal to 24V.
    #pin: ~!PB7
    ## For the DIAG_7 port. NEEDS BAT85 DIODE! Change to !PG15 if probe is NO.
    pin: PG15
    ## For Octopus Pro PROBE port; NPN and PNP proximity switch types can be set by jumper
    #pin: ~!PC5
    x_offset: 0
    y_offset: 25.0
    z_offset: 0
    speed: 10.0
    samples: 3
    samples_result: median
    sample_retract_dist: 3.0
    samples_tolerance: 0.006
    samples_tolerance_retries: 3
    #   Fan Control
    [fan]
    ##  Print Cooling Fan - FAN0
    pin: PA8
    kick_start_time: 0.5
    ##  Depending on your fan, you may need to increase this value
    ##  if your fan will not start. Can change cycle_time (increase)
    ##  if your fan is not able to slow down effectively
    off_below: 0.10
    [heater_fan hotend_fan]
    ##  Hotend Fan - FAN1
    pin: PE5
    max_power: 1.0
    heater: extruder
    heater_temp: 50.0
    ##  If you are experiencing back flow, you can reduce fan_speed
    fan_speed: 1.0
    [controller_fan controller_fan]
    ##  Controller fan - FAN2
    pin: PD12
    heater: heater_bed
    [heater_fan exhaust_fan]
    ##  Exhaust fan - FAN3
    pin: PD13
    max_power: 1.0
    shutdown_speed: 0.0
    kick_start_time: 5.0
    heater: heater_bed
    #heater_temp: 60
    fan_speed: 1.0
    #   LED Control
    ## Chamber Lighting - HE2 Connector (Optional)
    #[output_pin caselight]
    #pin: PB10
    #pwm:true
    #shutdown_value: 0
    #value:1
    #cycle_time: 0.01
    #   Homing and Gantry Adjustment Routines
    [idle_timeout]
    timeout: 1800
    [safe_z_home]
    ##  XY Location of the Z Endstop Switch
    ##  Update -10,-10 to the XY coordinates of your endstop pin
    ##  (such as 157,305) after going through Z Endstop Pin
    ##  Location Definition step.
    home_xy_position:231,355
    speed:100
    z_hop:10
    [quad_gantry_level]
    ##  Use QUAD_GANTRY_LEVEL to level a gantry.
    ##  Min & Max gantry corners - measure from nozzle at MIN (0,0) and
    ##  MAX (250, 250), (300,300), or (350,350) depending on your printer size
    ##  to respective belt positions
    ##  Gantry Corners for 250mm Build
    ##  Uncomment for 250mm build
    #gantry_corners:
    #   -60,-10
    #   310, 320
    ##  Probe points
    #points:
    #   50,25
    #   50,175
    #   200,175
    #   200,25
    ##  Gantry Corners for 300mm Build
    #gantry_corners:
    #   -60,-10
    #   360,370
    ##  Probe points
    #points:
    #   50,25
    #   50,225
    #   250,225
    #   250,25
    ##  Gantry Corners for 350mm Build
    gantry_corners:
       -60,-10
       410,420
    ##  Probe points
       50,25
       50,275
       300,275
       300,25
    speed: 100
    horizontal_move_z: 10
    retries: 5
    retry_tolerance: 0.0075
    max_adjust: 10
    # EXP1 / EXP2 (display) pins
    [board_pins]
    aliases:
        # EXP1 header
        EXP1_1=PE8, EXP1_2=PE7,
        EXP1_3=PE9, EXP1_4=PE10,
        EXP1_5=PE12, EXP1_6=PE13,    # Slot in the socket on this side
        EXP1_7=PE14, EXP1_8=PE15,
        EXP1_9=<GND>, EXP1_10=<5V>,
        # EXP2 header
        EXP2_1=PA6, EXP2_2=PA5,
        EXP2_3=PB1, EXP2_4=PA4,
        EXP2_5=PB2, EXP2_6=PA7,      # Slot in the socket on this side
        EXP2_7=PC15, EXP2_8=<RST>,
        EXP2_9=<GND>, EXP2_10=<5V>
    #   Displays
    ##  Uncomment the display that you have
    #[display]
    ##  RepRapDiscount 128x64 Full Graphic Smart Controller
    #lcd_type: st7920
    #cs_pin: EXP1_4
    #sclk_pin: EXP1_5
    #sid_pin: EXP1_3
    #menu_timeout: 40
    #encoder_pins: ^EXP2_5, ^EXP2_3
    #click_pin: ^!EXP1_2
    #[output_pin beeper]
    #pin: EXP1_1
    [display]
    ##  mini12864 LCD Display
    lcd_type: uc1701
    cs_pin: EXP1_3
    a0_pin: EXP1_4
    rst_pin: EXP1_5
    click_pin: ^!EXP1_2
    contrast: 63
    spi_software_miso_pin: EXP2_1
    spi_software_mosi_pin: EXP2_6
    spi_software_sclk_pin: EXP2_2
    [neopixel btt_mini12864]
    ##  To control Neopixel RGB in mini12864 display
    pin: EXP1_6
    chain_count: 3
    initial_RED: 0.1
    initial_GREEN: 0.5
    initial_BLUE: 0.0
    color_order: RGB
    ##  Set RGB values on boot up for each Neopixel.
    ##  Index 1 = display, Index 2 and 3 = Knob
    [delayed_gcode setdisplayneopixel]
    initial_duration: 1
    gcode:
            SET_LED LED=btt_mini12864 RED=1 GREEN=1 BLUE=1 INDEX=1 TRANSMIT=0
            #SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
            #SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
    #   Macros
    [gcode_macro G32]
    gcode:
        SAVE_GCODE_STATE NAME=STATE_G32
        G90
        G28
        QUAD_GANTRY_LEVEL
        G28
        ##  Uncomment for for your size printer:
        #G0 X125 Y125 Z30 F3600
        ##  Uncomment for 300 build
        #G0 X150 Y150 Z30 F3600
        G0 X175 Y175 Z30 F3600
        RESTORE_GCODE_STATE NAME=STATE_G32
    [gcode_macro PRINT_START]
    #   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
    gcode:
        G32                            ; home all axes
        G90                            ; absolute positioning
        G1 Z20 F3000                   ; move nozzle away from bed
    [gcode_macro PRINT_END]
    #   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    gcode:
        # safe anti-stringing move coords
        {% set th = printer.toolhead %}
        {% set x_safe = th.position.x + 20 * (1 if th.axis_maximum.x - th.position.x > 20 else -1) %}
        {% set y_safe = th.position.y + 20 * (1 if th.axis_maximum.y - th.position.y > 20 else -1) %}
        {% set z_safe = [th.position.z + 2, th.axis_maximum.z]|min %}
        SAVE_GCODE_STATE NAME=STATE_PRINT_END
        M400                           ; wait for buffer to clear
        G92 E0                         ; zero the extruder
        G1 E-5.0 F1800                 ; retract filament
        TURN_OFF_HEATERS
        G0 X{x_safe} Y{y_safe} Z{z_safe} F20000  ; move nozzle to remove stringing
        G0 X{th.axis_maximum.x//2} Y{th.axis_maximum.y - 2} F3600  ; park nozzle at rear
        M107                                     ; turn off fan
        BED_MESH_CLEAR
        RESTORE_GCODE_STATE NAME=STATE_PRINT_END
    [gcode_macro CANCEL_PRINT]
    #Cancel the actual running print
    rename_existing: CANCEL_PRINT_BASE
    gcode:
      TURN_OFF_HEATERS
      CANCEL_PRINT_BASE
    #*# <---------------------- SAVE_CONFIG ---------------------->
    #*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
    it is working now, but I don't know why ... but pid calibration ... it is working, data are stored et the end of config, default config on extruder or bed are automatic commented from klipper and then starts problems, it is necessary to cut it from there in put it to extruder/bed config place. And than it is working again.
  • I'm no klipper expert so special klipper questions are better asked at a klipper forum. All I can really help with is when there are issues between klipper behaviour and server. Especially since klipper can change behaviour any time there might come up new issues when klipper gets updated. That is why most kipper scripts get downloaded, so we can quickly fix breaking changes in most cases immediately without server update.
  • ok, tnx. But if you are able check pls fluid web interface ... it is possible to make there butons, scripts butons ...
  • You can add as many scripts and wizards in server as you want. They appear in console and manual control in a dropdown menu for selection in order sorted in g-code list. You can change it there with drag and drop.
