Enable video even if not recording
I was very surprised when I turned off time lapse and my video feed went away.
I was going to re-print a model at high resolution, (0.08mm) and didn't want to loose the 38seconds per layer extra to take video, but when I went to take a look in on its progress, NO VIDEO!
Please enable video even when not recording...
(or tell me what ai am doing wrong)
thanks for your consideration.
what do I need to set where so that time-lapse is idle, but the monitoring is still active?
do you mean they have active lightning or you get no images in webcam view?
Check webcam settings in server. Timelapse uses single image shorts so uses the jpg url. If you defined it as JPG+MJPG webcam in manual control/console and webcam tab we use MJPG stream url. So if you see nothing there the url for mjpg is probably wrong. You see it in config if it delivers no image while jpg url does.
