Adding Turkish characters
Hello, Recently, I shared a "uilang.h" file with you. I translated it to Turkish here, but I couldn't add some Turkish characters. These are the characters "ı","İ","ş","Ş","ğ","Ğ". How do I add these characters? I couldn't find octal code equivalents. Help me translate it fully. Thanks
  • Don't think it works as displays have a fixed non UTF-8 character set and codes also differ between display types. If you see the deg or german ü you see that we convert "ü" into "ue" even for some target displays. But that would be the solution to go, just you need to know codes for fonts used in display. So not really worth the work.
  • Thank you so much. Good work.
