Mass Portal Pharaoh ED, RADDS 1.5 , Thermistor problems
Hi!
I just got a Pharaoh ED.
When i got it the printer was partially disassembed due to some problems (Not shure what?)
I have now assemled it completely but now i am stuck.
The thermistor for the hotend was broken when i got it, so i replaced it with a 100K thermistor.
Not shure if that is the right one but something is wrong.
The temp for the bed is correct. but the hotend reads 72C and when i heat it up i get all kinds of numbers.
I have tested two different thermistors with same result.
Also it is not connected to the place where thermistors is supposed to be connected according to the manual.
They are connected to AUX/ADC and 5V (See picture) https://ibb.co/nRy4vRv
I have worked with this for 12 hours straight now and i am out of ideas.
Pse help.
Pse help.
If it used a thermistor the normal connector for first extruder is T0 in the Thermistors header. Just hope it was configured for it.
I have a Thermo-Couple from a multimeter and when connecting it i get the right values :-)
So far so good.
I hope i can get it up and running soon.
The printer have some kind of chip for it since the Thermo-couple goes to before it enters the board.
Do you have any advice on how to insulate the probe before putting it into the hotend?
I read that putting it in there without insulation it will be shorted and not read anything correct.
