Extruder no life :)
HI folks
I am using repetier 0,91 on my custom made prusa i3
have calibrate all motors and endstops
Only the extruder doesn not move, tryied to conect to e0 on ramps tryied on e1 no life
preheated the hotend nothing happens
tryed to extrude with pronterface nothing happnes
how to invert e0 to e1 in config.h
Driver orientation is correct
thank you you had right the driver was burned.
Now im geting a klicking nois from the extruder motor, and the shaft vibrates, but does not spinn.
thanks
iv tested it with a spare 42HBC110-25 but the 42HBC110-25 has 6wires now i need to figure out how to use it till a new nema17 arrives
thanks
