random Connection closed by os during print ... trying reconnect for 10 seconds to continue ... whil
random Connection closed by os during print ... trying reconnect for 10 seconds to continue ... while printing
Repetier-Server 1.2.1
Repeiter-firmware 1.0.4
It came on completely by accident, the printer has been printing for about a year without any problems.
It happens regularly every 1 to 3 hours.
I was changed an USB cable.
If pi - do you see undervoltage in the bolt menu?
If it happens note the exact time and open /var/log/syslog the same timestamp to see what linux did and why? Apart from undervoltage causing a usb disconnect I also have seen back EMF as reason in logs.
For linux there is an option to try to silently reconnect usb and continue print. As test do a test print, unplug usb cable and replug it within 10 seconds. This was added to make printers with such problems work seamlessly. But does not work on all boards and only if printer does not reset, but the option tries to keep dtr/dtr the same so it does not send reset signal.
Feb 18 21:51:34 RepetierServer systemd[1]: Starting Time & Date Service...
Feb 18 21:51:34 RepetierServer dbus-daemon[451]: [system] Successfully activated service 'org.freedesktop.timedate1'
Feb 18 21:51:34 RepetierServer systemd[1]: Started Time & Date Service.
Feb 18 21:52:04 RepetierServer systemd[1]: systemd-timedated.service: Succeeded.
Feb 18 21:52:04 RepetierServer kernel: [ 4407.540795] usb usb2-port1: over-current change #1
Feb 18 21:52:04 RepetierServer kernel: [ 4407.554270] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 18 21:52:04 RepetierServer kernel: [ 4407.554671] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 18 21:52:04 RepetierServer kernel: [ 4407.708242] usb 1-1-port1: over-current change #1
Feb 18 21:52:04 RepetierServer kernel: [ 4407.709785] usb usb2-port2: over-current change #1
Feb 18 21:52:04 RepetierServer kernel: [ 4407.869545] usb usb2-port3: over-current change #1
Feb 18 21:52:05 RepetierServer kernel: [ 4407.939982] usb 1-1-port2: over-current change #1
Feb 18 21:52:05 RepetierServer kernel: [ 4408.029551] usb usb2-port4: over-current change #1
Feb 18 21:52:05 RepetierServer kernel: [ 4408.180355] usb 1-1-port3: over-current change #1
Feb 18 21:52:05 RepetierServer kernel: [ 4408.189814] usb usb2-port1: over-current change #2
Feb 18 21:52:05 RepetierServer kernel: [ 4408.420084] usb 1-1.3: USB disconnect, device number 4
Feb 18 21:52:05 RepetierServer kernel: [ 4408.422432] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 21:52:05 RepetierServer kernel: [ 4408.426424] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 21:52:05 RepetierServer kernel: [ 4408.430435] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 21:52:05 RepetierServer kernel: [ 4408.434437] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 21:52:05 RepetierServer kernel: [ 4408.438557] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 21:52:05 RepetierServer thd[491]: Error reading device '/dev/input/event0'
Feb 18 21:52:05 RepetierServer kernel: [ 4408.859466] usb 1-1.3: new high-speed USB device number 6 using xhci_hcd
Feb 18 21:52:06 RepetierServer kernel: [ 4409.201738] usb 1-1.3: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.10
Feb 18 21:52:06 RepetierServer kernel: [ 4409.201761] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Feb 18 21:52:06 RepetierServer kernel: [ 4409.201779] usb 1-1.3: SerialNumber: 4CA434A0
Feb 18 21:52:06 RepetierServer kernel: [ 4409.203506] uvcvideo: Found UVC 1.00 device <unnamed> (046d:081b)
Feb 18 21:52:06 RepetierServer kernel: [ 4409.321783] input: UVC Camera (046d:081b) as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
Feb 18 21:52:07 RepetierServer kernel: [ 4410.509467] usb 1-1.3: set resolution quirk: cval->res = 384
Feb 18 21:52:07 RepetierServer kernel: [ 4410.519814] usb 1-1-port4: over-current change #1
Feb 18 21:52:07 RepetierServer mtp-probe: checking bus 1, device 6: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
Feb 18 21:52:07 RepetierServer mtp-probe: bus: 1, device: 6 was not an MTP device
Feb 18 21:52:07 RepetierServer systemd[1]: Stopping mjpg_streamer for picam...
Feb 18 21:52:07 RepetierServer systemd[1]: mjpg_streamer.service: Succeeded.
Feb 18 21:52:07 RepetierServer systemd[1]: Stopped mjpg_streamer for picam.
Feb 18 21:52:07 RepetierServer systemd[1]: Started mjpg_streamer for picam.
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Start from directory /usr/local/Repetier-Setup/bin
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Testing active webcams in /dev/v4l/by-path/*
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
Feb 18 21:52:07 RepetierServer kernel: [ 4410.761069] usb 1-1.1: USB disconnect, device number 5
Feb 18 21:52:07 RepetierServer kernel: [ 4410.762165] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Feb 18 21:52:07 RepetierServer kernel: [ 4410.762216] ch341 1-1.1:1.0: device disconnected
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Best resolution: 0 x 0 at 0
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index0
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Webcam does not support MJPG - using slower YUYV instead!
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index1
Feb 18 21:52:07 RepetierServer systemd-udevd[9450]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Feb 18 21:52:07 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index2
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Best resolution: 0 x 0 at 0
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index3
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Webcam does not support MJPG - using slower YUYV instead!
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0
Feb 18 21:52:08 RepetierServer kernel: [ 4411.059467] usb 1-1.1: new full-speed USB device number 7 using xhci_hcd
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Best resolution: 640 x 480 at 15
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0 on port 8080
Feb 18 21:52:08 RepetierServer startAllCams[9473]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 15 -q 85 -r 640x480 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streamer/www" -b
Feb 18 21:52:08 RepetierServer MJPG-streamer [9623]: starting application
Feb 18 21:52:08 RepetierServer MJPG-streamer [9623]: enabling daemon mode
Feb 18 21:52:08 RepetierServer startAllCams[9473]: enabling daemon modeforked to background (9627)
Feb 18 21:52:08 RepetierServer startAllCams[9473]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index1
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: Using V4L2 device.: /dev/video1
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: Desired Resolution: 640 x 480
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: Frames Per Second.: 15
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: Format............: JPEG
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: TV-Norm...........: DEFAULT
Feb 18 21:52:08 RepetierServer kernel: [ 4411.195848] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
Feb 18 21:52:08 RepetierServer kernel: [ 4411.195858] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Feb 18 21:52:08 RepetierServer kernel: [ 4411.195866] usb 1-1.1: Product: USB2.0-Serial
Feb 18 21:52:08 RepetierServer kernel: [ 4411.199868] ch341 1-1.1:1.0: ch341-uart converter detected
Feb 18 21:52:08 RepetierServer kernel: [ 4411.203600] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
Feb 18 21:52:08 RepetierServer mtp-probe: checking bus 1, device 7: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: HTTP TCP port........: 8080
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: HTTP Listen Address..: (null)
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: username:password....: disabled
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: commands.............: enabled
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Feb 18 21:52:08 RepetierServer MJPG-streamer [9627]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Feb 18 21:52:08 RepetierServer mtp-probe: bus: 1, device: 7 was not an MTP device
Feb 18 22:58:49 RepetierServer kernel: [ 8412.264661] usb usb2-port1: over-current change #3
Feb 18 22:58:49 RepetierServer kernel: [ 8412.279307] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 18 22:58:49 RepetierServer kernel: [ 8412.279728] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 18 22:58:49 RepetierServer kernel: [ 8412.396694] usb 1-1-port1: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.429411] usb usb2-port2: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.589370] usb usb2-port3: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.629855] usb 1-1-port2: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.749359] usb usb2-port4: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.870123] usb 1-1-port3: over-current change #2
Feb 18 22:58:49 RepetierServer kernel: [ 8412.909387] usb usb2-port1: over-current change #4
Feb 18 22:58:50 RepetierServer kernel: [ 8413.119690] usb 1-1.3: USB disconnect, device number 6
Feb 18 22:58:50 RepetierServer kernel: [ 8413.123541] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 22:58:50 RepetierServer kernel: [ 8413.127531] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 22:58:50 RepetierServer kernel: [ 8413.131552] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 22:58:50 RepetierServer kernel: [ 8413.135666] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 22:58:50 RepetierServer kernel: [ 8413.139671] uvcvideo: Failed to resubmit video URB (-19).
Feb 18 22:58:50 RepetierServer kernel: [ 8413.529130] usb 1-1.3: new high-speed USB device number 8 using xhci_hcd
Feb 18 22:58:50 RepetierServer kernel: [ 8413.871444] usb 1-1.3: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.10
Feb 18 22:58:50 RepetierServer kernel: [ 8413.871466] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Feb 18 22:58:50 RepetierServer kernel: [ 8413.871485] usb 1-1.3: SerialNumber: 4CA434A0
Feb 18 22:58:50 RepetierServer kernel: [ 8413.873143] uvcvideo: Found UVC 1.00 device <unnamed> (046d:081b)
Feb 18 22:58:51 RepetierServer kernel: [ 8413.991551] input: UVC Camera (046d:081b) as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input2
Feb 18 22:58:52 RepetierServer kernel: [ 8415.183943] usb 1-1.3: set resolution quirk: cval->res = 384
Feb 18 22:58:52 RepetierServer kernel: [ 8415.185185] usb 1-1-port4: over-current change #2
Feb 18 22:58:52 RepetierServer mtp-probe: checking bus 1, device 8: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
Feb 18 22:58:52 RepetierServer mtp-probe: bus: 1, device: 8 was not an MTP device
Feb 18 22:58:52 RepetierServer systemd[1]: Stopping mjpg_streamer for picam...
Feb 18 22:58:52 RepetierServer systemd[1]: mjpg_streamer.service: Succeeded.
Feb 18 22:58:52 RepetierServer systemd[1]: Stopped mjpg_streamer for picam.
Feb 18 22:58:52 RepetierServer systemd[1]: Started mjpg_streamer for picam.
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Start from directory /usr/local/Repetier-Setup/bin
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Testing active webcams in /dev/v4l/by-path/*
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Best resolution: 0 x 0 at 0
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index0
Feb 18 22:58:52 RepetierServer kernel: [ 8415.420301] usb 1-1.1: USB disconnect, device number 7
Feb 18 22:58:52 RepetierServer kernel: [ 8415.421505] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Feb 18 22:58:52 RepetierServer kernel: [ 8415.421548] ch341 1-1.1:1.0: device disconnected
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Webcam does not support MJPG - using slower YUYV instead!
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index1
Feb 18 22:58:52 RepetierServer systemd-udevd[15990]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index2
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index3
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Best resolution: 640 x 480 at 15
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0 on port 8080
Feb 18 22:58:52 RepetierServer startAllCams[16012]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps 15 -q 85 -r 640x480 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streamer/www" -b
Feb 18 22:58:52 RepetierServer MJPG-streamer [16158]: starting application
Feb 18 22:58:52 RepetierServer MJPG-streamer [16158]: enabling daemon mode
Feb 18 22:58:52 RepetierServer startAllCams[16012]: enabling daemon modeforked to background (16161)
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: Using V4L2 device.: /dev/video0
Feb 18 22:58:52 RepetierServer startAllCams[16012]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index1
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: Desired Resolution: 640 x 480
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: Frames Per Second.: 15
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: Format............: JPEG
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: TV-Norm...........: DEFAULT
Feb 18 22:58:52 RepetierServer kernel: [ 8415.719127] usb 1-1.1: new full-speed USB device number 9 using xhci_hcd
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: HTTP TCP port........: 8080
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: HTTP Listen Address..: (null)
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: username:password....: disabled
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: commands.............: enabled
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Feb 18 22:58:52 RepetierServer MJPG-streamer [16161]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Feb 18 22:58:52 RepetierServer kernel: [ 8415.855823] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
Feb 18 22:58:52 RepetierServer kernel: [ 8415.855833] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Feb 18 22:58:52 RepetierServer kernel: [ 8415.855841] usb 1-1.1: Product: USB2.0-Serial
Feb 18 22:58:52 RepetierServer kernel: [ 8415.859278] ch341 1-1.1:1.0: ch341-uart converter detected
Feb 18 22:58:52 RepetierServer kernel: [ 8415.864676] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
Feb 18 22:58:52 RepetierServer mtp-probe: checking bus 1, device 9: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
Feb 18 22:58:52 RepetierServer mtp-probe: bus: 1, device: 9 was not an MTP device
I think that it mean that i has broken usb cable?
Feb 19 10:50:25 RepetierServer dbus-daemon[451]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.1633' (uid=0 pid=18167 comm="timedatectl ")
Feb 19 10:50:26 RepetierServer systemd[1]: Starting Time & Date Service...
Feb 19 10:50:26 RepetierServer dbus-daemon[451]: [system] Successfully activated service 'org.freedesktop.timedate1'
Feb 19 10:50:26 RepetierServer systemd[1]: Started Time & Date Service.
Feb 19 10:50:56 RepetierServer systemd[1]: systemd-timedated.service: Succeeded.
Feb 19 10:51:30 RepetierServer dbus-daemon[451]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.1635' (uid=0 pid=18276 comm="timedatectl ")
Feb 19 10:51:30 RepetierServer systemd[1]: Starting Time & Date Service...
Feb 19 10:51:30 RepetierServer dbus-daemon[451]: [system] Successfully activated service 'org.freedesktop.timedate1'
Feb 19 10:51:30 RepetierServer systemd[1]: Started Time & Date Service.
Feb 19 10:51:48 RepetierServer kernel: [51192.318961] usb usb2-port1: over-current change #8
Feb 19 10:51:48 RepetierServer kernel: [51192.333599] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 19 10:51:48 RepetierServer kernel: [51192.335079] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Feb 19 10:51:48 RepetierServer kernel: [51192.452497] usb 1-1-port1: over-current change #5
Feb 19 10:51:48 RepetierServer kernel: [51192.482407] usb usb2-port2: over-current change #5
Feb 19 10:51:49 RepetierServer kernel: [51192.642352] usb usb2-port3: over-current change #5
Feb 19 10:51:49 RepetierServer kernel: [51192.692846] usb 1-1-port2: over-current change #5
Feb 19 10:51:49 RepetierServer kernel: [51192.802350] usb usb2-port4: over-current change #5
Feb 19 10:51:49 RepetierServer kernel: [51192.933181] usb 1-1-port3: over-current change #5
Feb 19 10:51:49 RepetierServer kernel: [51192.962391] usb usb2-port1: over-current change #9
Feb 19 10:51:49 RepetierServer kernel: [51193.172693] usb 1-1.3: USB disconnect, device number 12
Feb 19 10:51:49 RepetierServer kernel: [51193.174087] uvcvideo: Failed to resubmit video URB (-19).
Feb 19 10:51:49 RepetierServer kernel: [51193.178088] uvcvideo: Failed to resubmit video URB (-19).
Feb 19 10:51:49 RepetierServer kernel: [51193.184820] uvcvideo: Failed to resubmit video URB (-19).
Feb 19 10:51:49 RepetierServer kernel: [51193.186096] uvcvideo: Failed to resubmit video URB (-19).
Feb 19 10:51:49 RepetierServer kernel: [51193.190087] uvcvideo: Failed to resubmit video URB (-19).
Feb 19 10:51:50 RepetierServer kernel: [51193.592122] usb 1-1.3: new high-speed USB device number 15 using xhci_hcd
Feb 19 10:51:50 RepetierServer kernel: [51193.934511] usb 1-1.3: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.10
Feb 19 10:51:50 RepetierServer kernel: [51193.934534] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Feb 19 10:51:50 RepetierServer kernel: [51193.934553] usb 1-1.3: SerialNumber: 4CA434A0
Feb 19 10:51:50 RepetierServer kernel: [51193.936220] uvcvideo: Found UVC 1.00 device <unnamed> (046d:081b)
Feb 19 10:51:50 RepetierServer kernel: [51194.054800] input: UVC Camera (046d:081b) as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input5
Feb 19 10:51:51 RepetierServer kernel: [51195.245836] usb 1-1.3: set resolution quirk: cval->res = 384
Feb 19 10:51:51 RepetierServer kernel: [51195.247152] usb 1-1-port4: over-current change #5
Feb 19 10:51:51 RepetierServer mtp-probe: checking bus 1, device 15: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
Feb 19 10:51:51 RepetierServer mtp-probe: bus: 1, device: 15 was not an MTP device
Feb 19 10:51:51 RepetierServer systemd[1]: Stopping mjpg_streamer for picam...
Feb 19 10:51:51 RepetierServer systemd[1]: mjpg_streamer.service: Succeeded.
Feb 19 10:51:51 RepetierServer systemd[1]: Stopped mjpg_streamer for picam.
Feb 19 10:51:51 RepetierServer systemd[1]: Started mjpg_streamer for picam.
Feb 19 10:51:51 RepetierServer startAllCams[18438]: Start from directory /usr/local/Repetier-Setup/bin
Feb 19 10:51:51 RepetierServer startAllCams[18438]: Testing active webcams in /dev/v4l/by-path/*
Feb 19 10:51:51 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
Feb 19 10:51:51 RepetierServer startAllCams[18438]: Best resolution: 0 x 0 at 0
Feb 19 10:51:51 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index0
Feb 19 10:51:51 RepetierServer kernel: [51195.483469] usb 1-1.1: USB disconnect, device number 14
Feb 19 10:51:51 RepetierServer kernel: [51195.485095] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Feb 19 10:51:51 RepetierServer kernel: [51195.485137] ch341 1-1.1:1.0: device disconnected
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Webcam does not support MJPG - using slower YUYV instead!
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Best resolution: 0 x 0 at 0
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index1
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index2
Feb 19 10:51:52 RepetierServer systemd-udevd[18386]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Feb 19 10:51:52 RepetierServer mtp-probe: checking bus 1, device 15: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
Feb 19 10:51:52 RepetierServer mtp-probe: bus: 1, device: 15 was not an MTP device
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-bcm2835-isp-video-index3
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Best resolution: 640 x 480 at 15
Feb 19 10:51:52 RepetierServer kernel: [51195.782157] usb 1-1.1: new full-speed USB device number 16 using xhci_hcd
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0 on port 8080
Feb 19 10:51:52 RepetierServer startAllCams[18438]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 15 -q 85 -r 640x480 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8080 -w /usr/local/share/mjpg-streamer/www" -b
Feb 19 10:51:52 RepetierServer MJPG-streamer [18585]: starting application
Feb 19 10:51:52 RepetierServer MJPG-streamer [18585]: enabling daemon mode
Feb 19 10:51:52 RepetierServer startAllCams[18438]: enabling daemon modeforked to background (18589)
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: Using V4L2 device.: /dev/video1
Feb 19 10:51:52 RepetierServer startAllCams[18438]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index1
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: Desired Resolution: 640 x 480
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: Frames Per Second.: 15
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: Format............: JPEG
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: TV-Norm...........: DEFAULT
Feb 19 10:51:52 RepetierServer kernel: [51195.918502] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
Feb 19 10:51:52 RepetierServer kernel: [51195.918512] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Feb 19 10:51:52 RepetierServer kernel: [51195.918520] usb 1-1.1: Product: USB2.0-Serial
Feb 19 10:51:52 RepetierServer kernel: [51195.921005] ch341 1-1.1:1.0: ch341-uart converter detected
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: HTTP TCP port........: 8080
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: HTTP Listen Address..: (null)
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: username:password....: disabled
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: commands.............: enabled
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
Feb 19 10:51:52 RepetierServer MJPG-streamer [18589]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
Feb 19 10:51:52 RepetierServer kernel: [51195.926957] usb 1-1.1: ch341-uart converter now attached to ttyUSB0
Feb 19 10:51:52 RepetierServer mtp-probe: checking bus 1, device 16: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
Feb 19 10:51:52 RepetierServer mtp-probe: bus: 1, device: 16 was not an MTP device
That is bad overcurrent and also the usb read error following. You also see linux disconnects usb devices here. And it seems you have several devices on same port - al least several ports report overcurrent. So is this a hub in between?
One thing you can try is remove 5V pin from printer to pi as described here:
https://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/
then we get no power over usb from printer and printer also does not draw power when unconnected.
Also one tip for testing your problems. Login via ssh and run this command:
tail -f /var/log/syslog | grep usb
it will directly show in that window any usb related messages. So you can directly see what happened. Next step must be to determine where the problems exactly come from, see if taping 5v helps or if e.g. a webcam or whatever is connected causes problems. But overcurrent must come from a device with own power. Plus undervoltage might also be an error but might also improve with taping 5v.
If the printer is turned on all day continuously and without work, there will be these errors
Your pi suffered from undervoltage! This can cause instabilities and a lot of errors. See
On pi 4 it can also make a difference if you use usb 2 or usb 3 ports. Since printers use usb 2 and can not talk faster usb 3 has no advantage anyway.
But i can`t see the icon. I dont know why.
But I see it in your ssh shell and it would not differ. So you have at least had undervoltage and it is a potential issue - also not always. You could try the 5v pin taping solution to reduce usage by printer. Then printer will also only show up if main power is enabled. Reduces usage by 300-500mA depending on what your printer has all connected to it.
throttled=0x50000
that is the script delivering the content for bolt icon. Question is if it crashes or does not run or even does not exist to narrow why it does not appear.
But that is not really relevant here for your issue. We already know you had undervoltage and it would just show the same when it runs. But would still be interesting why it fails for you in case it is something I can fix.
pi@RepetierServer:~ $ /var/lib/Repetier-Server/scripts/hardware_info
-bash: /var/lib/Repetier-Server/scripts/hardware_info: Permission denied
pi@RepetierServer:~ $ sudo /var/lib/Repetier-Server/scripts/hardware_info
sudo: /var/lib/Repetier-Server/scripts/hardware_info: command not found
The sudo /var/lib/Repetier-Server/scripts/hardware_info works for me but from message I have to assume that the file is just missing. So deleted file and reinstalled server (it keeps all setting) and it created the file again. So no idea why you do not have the file as installing 1.3.0 should have added the file. But the fact that it is missing is the reason you do not see it in gui.
So as solution I suggest reinstalling the latest version. In newer images all you need to execute is
installLatestServer
and it will fetch and install latest version.
pi@RepetierServer:~ $ cat /var/lib/Repetier-Server/scripts/hardware_info
#!/bin/bash
# For raspberry we have some extra tests
if [ -x "$(command -v vcgencmd)" ] ; then
TEMP=$(vcgencmd measure_temp | cut -d= -f2 | cut -d\' -f1)
STFLAGS=$(vcgencmd get_throttled |cut -d= -f2)
WAS_UNDERVOLTAGE=$((($STFLAGS & 0x10000)!=0))
IS_UNDERVOLTAGE=$((($STFLAGS & 0x1)!=0))
WAS_THROTTLED=$((($STFLAGS & 0x40000)!=0))
IS_THROTTLED=$((($STFLAGS & 0x4)!=0))
WAS_SOFT_TEMP_ACTIVE=$((($STFLAGS & 0x80000)!=0))
IS_SOFT_TEMP_ACTIVE=$((($STFLAGS & 0x8)!=0))
if [ "$IS_UNDERVOLTAGE" == "1" ] ; then
echo -e "Undervoltage:\t0\t\tNow\t3\t3\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
elif [ "$WAS_UNDERVOLTAGE" == "1" ] ; then
echo -e "Undervoltage:\t0\t\tIn past\t2\t3\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
else
echo -e "Undervoltage:\t0\t\tNever\t1\t1\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
fi
if [ "$IS_THROTTLED" == "1" ] ; then
echo -e "CPU throttled:\t0\t\tNow\t3\t3\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
elif [ "$WAS_THROTTLED" == "1" ] ; then
echo -e "CPU throttled:\t0\t\tIn past\t2\t3\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
else
echo -e "CPU throttled:\t0\t\tNever\t1\t17\thttps://www.repetier-server.com/knowledgebase/undervoltage-and-throtteling-of-pi/"
fi
echo -e "CPU temperature:\t1\t°C\t$TEMP\t1\t2\t"
fi
W=$(w | grep load)
REGEX="load average:[ ]*(.*)"
if [[ $W =~ $REGEX ]] ; then
LOAD="${BASH_REMATCH[1]}"
echo -e "CPU load:\t0\t\t$LOAD\t1\t17\t"
fi
FREEMEMORY=$(cat /proc/meminfo | grep MemAvailable | cut -d: -f2 | awk '{$1=$1};1')
if [[ "$FREEMEMORY" == *kB ]] ; then
FREEMEMORY="$(($(echo "$FREEMEMORY"| cut -d' ' -f1) / 1024)) MB"
fi
echo -e "Free RAM:\t0\t\t$FREEMEMORY\t1\t17\t"
# Disk usage, warn when 90% is used, error if 95% is used
df -m -l -h --output=avail,pcent,target,source | while read line ; do
ARRAY=($line)
DEV=${ARRAY[3]}
AVAILABLE=${ARRAY[0]}
USE=${ARRAY[1]}
USEVAL=${USE%?}
MOUNT=${ARRAY[2]}
if [[ "$DEV" == "tmpfs" ]] ; then
continue
fi
if [[ "$DEV" == "udev" ]] ; then
continue
fi
if [[ "$AVAILABLE" == "Avail" ]] ; then
continue
fi
if [[ "$DEV" == "devtmpfs" ]] ; then
continue
fi
if [[ "$MOUNT" == "/boot" ]] ; then
continue
fi
if [[ $MOUNT == *"/snap/"* ]]; then
continue
fi
LEVEL=1
if (( USEVAL >= 90 )) ; then
LEVEL=2
fi
if (( USEVAL >= 95 )) ; then
LEVEL=3
fi
echo -e "$MOUNT :\t0\t\tFree ${AVAILABLE}B\t$LEVEL\t14\t"
done
DATE=$(date)
echo -e "Date and time:\t0\t\t${DATE}\t1\t18\t"
REGEX="up (.*)...[0-9]+ user"
UPTIME="${BASH_REMATCH[1]}"
echo -e "PC uptime:\t0\t\t${UPTIME}\t1\t18\t"
fi
I reinstalled, it not helped
pi@RepetierServer:~ $ installLatestServer
rm: cannot remove 'RepetierServerLatest.deb': No such file or directory
Raspberry with v7 or newer command set found. Installing armhf version...
--2022-05-21 15:23:41-- http://download.repetier.com/files/server/debian-armhf/RepetierServerLatest.deb
Resolving download.repetier.com (download.repetier.com)... 188.138.1.8, 94.130.164.39
Connecting to download.repetier.com (download.repetier.com)|188.138.1.8|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 49852200 (48M) [application/octet-stream]
Saving to: ‘RepetierServerLatest.deb’
RepetierServerLatest.deb 100%[===================================================================================================================>] 47.54M 3.66MB/s in 15s
2022-05-21 15:23:57 (3.12 MB/s) - ‘RepetierServerLatest.deb’ saved [49852200/49852200]
(Reading database ... 76541 files and directories currently installed.)
Preparing to unpack RepetierServerLatest.deb ...
Uninstall Repetier-Server
Removed /etc/systemd/system/multi-user.target.wants/RepetierServer.service.
Unpacking repetier-server (1.3.0) over (1.3.0) ...
Setting up repetier-server (1.3.0) ...
Install Repetier-Server
Created symlink /etc/systemd/system/multi-user.target.wants/RepetierServer.service → /lib/systemd/system/RepetierServer.service.
Processing triggers for systemd (241-7~deb10u8+rpi1) ...
,ooolcloooo: 'oooooccloo: OS: Raspbian 10 buster
.looooc;;:ol :oc;;:ooooo' Kernel: armv7l Linux 5.10.103-v7l+
;oooooo: ,ooooooc. Uptime: 2d 5h 24m
.,:;'. .;:;'. Packages: 909
.... ..'''''. .... Shell: 4983
.''. ..'''''. ..''. CPU: ARMv7 rev 3 (v7l) @ 4x 1.5GHz [54.5°C]
.. ..... ..... .. GPU:
. .''''''' .''''''. . RAM: 80MiB / 870MiB
ls -l /var/lib/Repetier-Server/scripts/
show. Also what does
now show. I mean when the program is there as you say and if it has x permission it should be executable.
Upgrading to bullseye is no option - at least if you have a pi cam it will not work with mjpg_streamer any more.
pi@RepetierServer:~ $ ls -l /var/lib/Repetier-Server/scripts/
total 12
-rw-r----- 1 repetierserver dialout 2875 Aug 6 2021 hardware_info
-rw-r----- 1 repetierserver dialout 194 Aug 6 2021 mountflash
-rw-r----- 1 repetierserver dialout 52 Aug 6 2021 unmountflash
I have no a pi cam. I has Bus 001 Device 003: ID 046d:081b Logitech, Inc. Webcam C310. Will be think about upgrade the Debian to 11. Thx!
sudo chmod a+rx /var/lib/Repetier-Server/scripts/hardware_info
and then it should start to appear after a minute.
I found the bug in our post install script where there was a type in the line setting permissions. Only users with newer images did get it, because the script is there preinstalled correctly with execute permissions. Thanks for finding the issue.
It work thx!
