How to install Klipper on Windows?
Hi! I wanted to install klipper on my Minipc that is running Repetier Server with Windows.
I am using it as a server for 2 3dprinters (ender 3) but I can't find any tutorials on how to install klipper properly, since all of them are about other OSs (Octopi or Fluid) and none are for Repetier.
I found this in the docs "Already during installation with the printer wizard, you get offered to
install the klipper daemon. You should always do this, even if you do
not have a configuration yet." but I don't know how/can't do that on the Wizard
I tried adding a new printer with the wizard and selecting Klipper as firmware but it doesn't connect (I guess it is because Klipper firm isn't installed in the 3DPrinter) and I don't know how to proceed.
What might work (untested) is using WSL2 on windows, install Repetier-Server there and then use the klipper installation. WSL2 is linux under windows subsystem.
We have our own scripts as we install it with user repetierserver to solve some permission issues as well. But we do more or less the same, just different folders and config path so we can also edit klipper config inside repetier server.
Sondern nur wenn ich sie in die manuelle Steuerung eintrage. Kann man dies ändern?
