Height false after printing
Hi everyone.
I have a part I want to print that should have a height of 49.9mm... the gcode I'm using was working with octoprint correctly, so the print has exact 49.9mm. But when I use the same gcode on repetier server the part is 52.2mm height after printing and that's a no go, it has to be exact 49.9mm.
I tried already to reslice and make a new gcode, but the same problem appears... any suggestions?
Kind regards
Gurry
Kind regards
Gurry
