Auto Leveling
I have a problem with the AutoLeveling fonction on my Prusa.
When I works from Repeter Host directely connected to my Prusa by USB, this fonction works fine with the folowing code at the begining :
M104 S200 ; set temperature
G91 ; Coord en relatif
G1 Z20 ; remonter Z de 20mm
G90 ; Coord absolue
G28 ; Homing XYZ
G29; Auto Leveling
M500; enregistrer les paramètres dans l'EEPROM
M109 S200 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
When I works with Repetier Server the code G29 do not appear in the log of the command send to the printer (>Console Screen with Commande ON).
I have add the following code in the printer configuration in the section "Run Before Job"
G90 ; Coord absolue
G28 ; Homing XYZ
G29; Auto Leveling
but without success.
Christian
