Auto Leveling
  I have a problem with the AutoLeveling fonction on my Prusa.
  When I works from Repeter Host directely connected to my Prusa by USB, this fonction works fine with the folowing code at the begining :
M104 S200 ; set temperature
G91 ; Coord en relatif
G1 Z20 ; remonter Z de 20mm
G90 ; Coord absolue
G28 ; Homing XYZ
G29; Auto Leveling
M500; enregistrer les paramètres dans l'EEPROM
M109 S200 ; wait for temperature to be reached
M82 ; use absolute distances for extrusion
G92 E0
When I works with Repetier Server the code G29 do not appear in the log of the command send to the printer (>Console Screen with Commande ON).
I have add the following code in the printer configuration in the section "Run Before Job"
G90 ; Coord absolue
G28 ; Homing XYZ
G29; Auto Leveling
but without success.
Christian
  • The server has a bug that it ignores commands with comments without space between command and comment.
    Write
    G29 ; Auto leveling
    instead and it works.
    Why M500 if you throw results away for every print? It only costs write cycles of eeprom without added benefit.
  • Thanks for the information.  The problem was effectively from the comments without space before.
    Now it works.
    About the M500, effectively, they are no sens.  This is a copy-past from the documentation deliver with my printer
    Thanks again for your support.
