Host fails to connect to Windows
I receive the following error....how can I correct?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at RepetierHostExtender.basic.GCodeAnalyzer.arc(Single[] position, Single[] target, Single[] offset, Single radius, Boolean isclockwise, GCode code)
   at RepetierHostExtender.basic.GCodeAnalyzer.analyzeShort(GCodeShort code)
   at RepetierHostExtender.basic.Printjob.PushGCodeShortArray(List`1 codes)
   at RepetierHost.connector.SerialConnector.RunJob()
   at System.Windows.Forms.ToolStripSplitButton.OnButtonClick(EventArgs e)
   at System.Windows.Forms.ToolStripSplitButton.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4470.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RepetierHost
    Assembly Version: 2.2.4.0
    Win32 Version: 2.2.4.0
    CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHost.exe
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4395.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHostExtender.DLL
System.Configuration
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    Win32 Version: 4.8.4161.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
OpenTK
    Assembly Version: 3.1.0.0
    Win32 Version: 3.1.0
    CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.DLL
ColorSlider
    CodeBase: file:///C:/Program%20Files/Repetier-Host/ColorSlider.DLL
CuraEngine
    CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/CuraEngine/CuraEngine.dll
RepetierServerConnector
    CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/RepetierServerConnector.dll
RRFirmwares
    CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RRFirmwares/RRFirmwares.dll
SlicerSlic3r
    CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3r/SlicerSlic3r.dll
SlicerSlic3rPE
    CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3rPE/SlicerSlic3rPE.dll
System.ServiceProcess
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Newtonsoft.Json
    Assembly Version: 6.0.0.0
    Win32 Version: 6.0.8.18111
    CodeBase: file:///C:/Program%20Files/Repetier-Host/Newtonsoft.Json.DLL
OpenTK.GLControl
    CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.GLControl.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  • Looks like you try to start a print with arcs (G2/G3) and something in it causes the error. I need the gcode to see what happens hoping I get same crash, just with sources for analysis.
  • Thanks for the reply.
    The gcode I used is generated from Estlcam
    ;Project senior_haydin_16th
    ;Created by Estlcam version 11 build 11.243
    ;Machining time about 00:03:08 hours
    G90
    M03 S24000
    G00 X0.0000 Y0.0000 Z0.0000 F2100
    G00 Z4.0000 F480
    ;No. 1: Hole 14
    G00 X83.2310 Y30.5787 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360 S24000
    G01 Z-1.5000 F360
    G01 X85.3943 F1200
    G01 Y31.2931 F1200
    G01 X83.2310 F1200
    G01 Y32.0074 F1200
    G01 X85.3943 F1200
    G01 Y32.7218 F1200
    G01 X83.2310 F1200
    G01 Y33.4362 F1200
    G01 X85.3943 F1200
    G01 Y34.1506 F1200
    G01 X83.2310 F1200
    G01 Y34.8649 F1200
    G01 X85.3943 F1200
    G01 Y35.5793 F1200
    G01 X83.2310 F1200
    G01 Y36.2937 F1200
    G01 X85.3943 F1200
    G01 Y37.0081 F1200
    G01 X83.2310 F1200
    G01 Y37.7224 F1200
    G01 X85.3948 F1200
    G01 Y38.4368 F1200
    G01 X85.7429 F1200
    G01 X83.2310 F1200
    G01 Y39.1512 F1200
    G01 X93.6500 F1200
    G01 X93.0069 F1200
    G01 Y38.4368 F1200
    G01 X89.5823 F1200
    G01 X91.0252 F1200
    G01 Y37.7224 F1200
    G01 X93.1426 F1200
    G01 X94.0701 Y37.0081 F1200
    G01 X91.7955 F1200
    G01 X92.4092 Y36.2937 F1200
    G01 X94.9242 F1200
    G01 X95.5670 Y35.5793 F1200
    G01 X92.9819 F1200
    G01 X93.5353 Y34.8649 F1200
    G01 X96.0862 F1200
    G01 X96.5558 Y34.1506 F1200
    G01 X94.0480 F1200
    G01 X94.4965 Y33.4362 F1200
    G01 X96.9988 F1200
    G01 X97.4239 Y32.7218 F1200
    G01 X94.9450 F1200
    G01 X95.3935 Y32.0074 F1200
    G01 X97.8698 F1200
    G01 X98.3182 Y31.2931 F1200
    G01 X95.8420 F1200
    G01 X96.2905 Y30.5787 F1200
    G01 X98.7666 F1200
    G00 Z4.0000 F480
    G00 X83.2310 Y39.1512 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y39.8656 F1200
    G01 X95.8855 F1200
    G01 X96.8182 Y40.5799 F1200
    G01 X93.3386 F1200
    G01 X94.7835 F1200
    G01 Y41.2943 F1200
    G01 X97.3637 F1200
    G01 X97.7080 Y42.0087 F1200
    G01 X95.4000 F1200
    G01 X95.7233 Y42.7231 F1200
    G01 X97.9165 F1200
    G01 X98.0222 Y43.4374 F1200
    G01 X95.8674 F1200
    G01 X95.8773 Y44.1518 F1200
    G01 X98.0486 F1200
    G01 X97.9962 Y44.8662 F1200
    G01 X95.7552 F1200
    G01 X95.4514 Y45.5806 F1200
    G01 X97.8512 F1200
    G01 X97.5895 Y46.2949 F1200
    G01 X94.8662 F1200
    G01 Y47.0093 F1200
    G01 X93.5869 F1200
    G01 X97.1848 F1200
    G01 X96.5751 Y47.7237 F1200
    G01 X83.2310 F1200
    G01 Y47.0093 F1200
    G01 X85.7242 F1200
    G01 X85.3944 F1200
    G01 Y46.2949 F1200
    G01 X83.2310 F1200
    G01 Y45.5806 F1200
    G01 X85.3943 F1200
    G01 Y44.8662 F1200
    G01 X83.2310 F1200
    G01 Y44.1518 F1200
    G01 X85.3943 F1200
    G01 Y43.4374 F1200
    G01 X83.2310 F1200
    G01 Y42.7231 F1200
    G01 X85.3943 F1200
    G01 Y42.0087 F1200
    G01 X83.2310 F1200
    G01 Y41.2943 F1200
    G01 X85.3948 F1200
    G01 Y40.5799 F1200
    G01 X85.7429 F1200
    G01 X85.8287 Y40.7155 F1200
    G03 X86.3468 Y40.5228 I0.5177 J0.5992 F1200
    G03 X91.6055 Y40.5620 I1.9348 J93.2881 F1200
    G03 X93.3074 Y40.7356 I-0.1854 J10.2438 F1200
    G03 X95.7294 Y43.8609 I-0.6092 J2.9733 F1200
    G03 X93.3671 Y46.9094 I-3.0124 J0.1052 F1200
    G03 X91.4149 Y47.0722 I-1.6202 J-7.6451 F1200
    G03 X86.2303 Y47.0740 I-2.6993 J-306.7925 F1200
    G03 X85.5530 Y46.2889 I0.1165 J-0.7852 F1200
    G01 Y41.3165 F1200
    G03 X85.8287 Y40.7155 I0.7922 J-0.0004 F1200
    G01 X85.7429 Y40.5799 F1200
    G01 X83.2310 F1200
    G00 Z4.0000 F480
    G00 Y47.7237 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y48.4381 F1200
    G01 X95.4222 F1200
    G01 X95.5423 Y48.5602 F1200
    G02 X97.8277 Y46.1465 I-1.6519 J-3.8529 F1200
    G02 X97.6708 Y41.5210 I-5.6859 J-2.1226 F1200
    G02 X95.0848 Y39.3347 I-3.8495 J1.9308 F1200
    G02 X93.7576 Y39.0165 I-2.5594 J7.7484 F1200
    G03 X93.5120 Y37.5751 I0.1819 J-0.7726 F1200
    G02 X96.3535 Y34.7539 I-4.2337 J-7.1056 F1200
    G02 X99.3767 Y29.9053 I-815.3873 J-511.7756 F1200
    G01 X96.5258 F1200
    G01 X93.7738 Y34.2888 F1200
    G03 X91.4928 Y37.0980 I-25.8674 J-18.6735 F1200
    G03 X88.6358 Y38.4354 I-3.0777 J-2.8542 F1200
    G03 X86.2303 Y38.4854 I-1.6962 J-23.7332 F1200
    G03 X85.5530 Y37.7002 I0.1165 J-0.7852 F1200
    G01 Y29.9053 F1200
    G01 X83.0723 F1200
    G01 Y49.1114 F1200
    G01 X90.9625 F1200
    G02 X94.8784 Y48.7725 I0.4698 J-17.3629 F1200
    G02 X95.5423 Y48.5602 I-0.7676 J-3.5441 F1200
    G01 X95.4222 Y48.4381 F1200
    G00 Z4.0000 F480
    ;No. 2: Hole 9
    G00 X103.5727 Y48.4381 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X105.7360 F1200
    G01 Y47.7237 F1200
    G01 X103.5727 F1200
    G01 Y47.0093 F1200
    G01 X105.7360 F1200
    G01 Y46.2949 F1200
    G01 X103.5727 F1200
    G01 Y45.5806 F1200
    G01 X105.7360 F1200
    G01 Y44.8662 F1200
    G01 X103.5727 F1200
    G01 Y44.1518 F1200
    G01 X105.7360 F1200
    G01 Y43.4374 F1200
    G01 X103.5727 F1200
    G01 Y42.7231 F1200
    G01 X105.7360 F1200
    G01 Y42.0087 F1200
    G01 X103.5727 F1200
    G01 Y41.2943 F1200
    G01 X105.7360 F1200
    G01 Y40.5799 F1200
    G01 X103.5727 F1200
    G01 Y39.8656 F1200
    G01 X105.7360 F1200
    G01 Y39.1512 F1200
    G01 X103.5727 F1200
    G01 Y38.4368 F1200
    G01 X105.7360 F1200
    G01 Y37.7224 F1200
    G01 X103.5727 F1200
    G01 Y37.0081 F1200
    G01 X105.7360 F1200
    G01 Y36.2937 F1200
    G01 X103.5727 F1200
    G01 Y35.5793 F1200
    G01 X105.7360 F1200
    G01 Y34.8649 F1200
    G01 X103.5727 F1200
    G01 Y34.1506 F1200
    G01 X105.7360 F1200
    G01 Y33.4362 F1200
    G01 X103.5727 F1200
    G01 Y32.7218 F1200
    G01 X105.7360 F1200
    G01 Y32.0074 F1200
    G01 X103.5727 F1200
    G01 Y31.2931 F1200
    G01 X105.7360 F1200
    G01 Y30.5787 F1200
    G01 X103.5727 F1200
    G01 X103.4140 Y30.5965 F1200
    G01 Y49.1114 F1200
    G01 X105.8947 F1200
    G01 Y29.9053 F1200
    G01 X103.4140 F1200
    G01 Y30.5965 F1200
    G01 X103.5727 Y30.5787 F1200
    G00 Z4.0000 F480
    ;No. 3: Hole 8
    G00 X112.1614 Y30.5787 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X114.3246 F1200
    G01 Y31.2931 F1200
    G01 X112.1614 F1200
    G01 Y32.0074 F1200
    G01 X114.3246 F1200
    G01 Y32.7218 F1200
    G01 X112.1614 F1200
    G01 Y33.4362 F1200
    G01 X114.3246 F1200
    G01 Y34.1506 F1200
    G01 X112.1614 F1200
    G01 Y34.8649 F1200
    G01 X114.3246 F1200
    G01 Y35.5793 F1200
    G01 X112.1614 F1200
    G01 Y36.2937 F1200
    G01 X114.3246 F1200
    G01 Y37.0081 F1200
    G01 X112.1614 F1200
    G01 Y37.7224 F1200
    G01 X114.3246 F1200
    G01 X114.3683 Y38.4368 F1200
    G01 X112.1614 F1200
    G01 Y39.1512 F1200
    G01 X122.9132 F1200
    G01 Y39.8656 F1200
    G01 X112.1614 F1200
    G01 Y40.5799 F1200
    G01 X122.9132 F1200
    G01 X114.4513 F1200
    G01 Y41.2943 F1200
    G01 X112.1614 F1200
    G01 Y42.0087 F1200
    G01 X114.3246 F1200
    G01 Y42.7231 F1200
    G01 X112.1614 F1200
    G01 Y43.4374 F1200
    G01 X114.3246 F1200
    G01 Y44.1518 F1200
    G01 X112.1614 F1200
    G01 Y44.8662 F1200
    G01 X114.3246 F1200
    G01 Y45.5806 F1200
    G01 X112.1614 F1200
    G01 Y46.2949 F1200
    G01 X114.3248 F1200
    G01 Y47.0093 F1200
    G01 X114.6545 F1200
    G01 X112.1614 F1200
    G01 Y47.7237 F1200
    G01 X124.2692 F1200
    G01 Y48.4381 F1200
    G01 X112.1614 F1200
    G01 X112.0026 Y48.4203 F1200
    G01 Y49.1114 F1200
    G01 X124.4280 F1200
    G01 Y47.0826 F1200
    G01 X115.2771 F1200
    G03 X114.4834 Y46.2889 I0.0000 J-0.7937 F1200
    G01 Y41.7684 F1200
    G03 X115.2771 Y40.9747 I0.7938 J0.0000 F1200
    G01 X123.0720 F1200
    G01 Y38.9459 F1200
    G01 X115.2771 F1200
    G03 X114.4834 Y38.1521 I0.0000 J-0.7937 F1200
    G01 Y29.9053 F1200
    G01 X112.0026 F1200
    G01 Y48.4203 F1200
    G01 X112.1614 Y48.4381 F1200
    G00 Z4.0000 F480
    ;No. 4: Hole 7
    G00 X129.7906 Y48.4381 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X131.9538 F1200
    G01 Y47.7237 F1200
    G01 X129.7906 F1200
    G01 Y47.0093 F1200
    G01 X131.9538 F1200
    G01 Y46.2949 F1200
    G01 X129.7906 F1200
    G01 Y45.5806 F1200
    G01 X131.9538 F1200
    G01 Y44.8662 F1200
    G01 X129.7906 F1200
    G01 Y44.1518 F1200
    G01 X131.9538 F1200
    G01 Y43.4374 F1200
    G01 X129.7906 F1200
    G01 Y42.7231 F1200
    G01 X131.9538 F1200
    G01 Y42.0087 F1200
    G01 X129.7906 F1200
    G01 Y41.2943 F1200
    G01 X131.9538 F1200
    G01 Y40.5799 F1200
    G01 X129.7906 F1200
    G01 Y39.8656 F1200
    G01 X131.9538 F1200
    G01 Y39.1512 F1200
    G01 X129.7906 F1200
    G01 Y38.4368 F1200
    G01 X131.9538 F1200
    G01 Y37.7224 F1200
    G01 X129.7906 F1200
    G01 Y37.0081 F1200
    G01 X131.9538 F1200
    G01 Y36.2937 F1200
    G01 X129.7906 F1200
    G01 Y35.5793 F1200
    G01 X131.9538 F1200
    G01 Y34.8649 F1200
    G01 X129.7906 F1200
    G01 Y34.1506 F1200
    G01 X131.9538 F1200
    G01 Y33.4362 F1200
    G01 X129.7906 F1200
    G01 Y32.7218 F1200
    G01 X131.9539 F1200
    G01 Y32.0074 F1200
    G01 X132.2837 F1200
    G01 X129.7906 F1200
    G01 Y31.2931 F1200
    G01 X142.3506 F1200
    G01 Y30.5787 F1200
    G01 X129.7906 F1200
    G01 X129.6318 Y30.5965 F1200
    G01 Y49.1114 F1200
    G01 X132.1125 F1200
    G01 Y32.7279 F1200
    G03 X132.9063 Y31.9342 I0.7937 J0.0000 F1200
    G01 X142.5093 F1200
    G01 Y29.9053 F1200
    G01 X129.6318 F1200
    G01 Y30.5965 F1200
    G01 X129.7906 Y30.5787 F1200
    G00 Z4.0000 F480
    ;No. 5: Hole 6
    G00 X147.4200 Y30.5787 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X161.3360 F1200
    G01 Y31.2931 F1200
    G01 X147.4200 F1200
    G01 Y32.0074 F1200
    G01 X149.9131 F1200
    G01 X149.5834 F1200
    G01 Y32.7218 F1200
    G01 X147.4200 F1200
    G01 Y33.4362 F1200
    G01 X149.5832 F1200
    G01 Y34.1506 F1200
    G01 X147.4200 F1200
    G01 Y34.8649 F1200
    G01 X149.5832 F1200
    G01 Y35.5793 F1200
    G01 X147.4200 F1200
    G01 Y36.2937 F1200
    G01 X149.5832 F1200
    G01 Y37.0081 F1200
    G01 X147.4200 F1200
    G01 Y37.7224 F1200
    G01 X149.5832 F1200
    G01 X149.6270 Y38.4368 F1200
    G01 X147.4200 F1200
    G01 Y39.1512 F1200
    G01 X159.9800 F1200
    G01 Y39.8656 F1200
    G01 X147.4200 F1200
    G01 Y40.5799 F1200
    G01 X159.9800 F1200
    G01 X149.7100 F1200
    G01 Y41.2943 F1200
    G01 X147.4200 F1200
    G01 Y42.0087 F1200
    G01 X149.5832 F1200
    G01 Y42.7231 F1200
    G01 X147.4200 F1200
    G01 Y43.4374 F1200
    G01 X149.5832 F1200
    G01 Y44.1518 F1200
    G01 X147.4200 F1200
    G01 Y44.8662 F1200
    G01 X149.5832 F1200
    G01 Y45.5806 F1200
    G01 X147.4200 F1200
    G01 Y46.2949 F1200
    G01 X149.5834 F1200
    G01 Y47.0093 F1200
    G01 X149.9131 F1200
    G01 X147.4200 F1200
    G01 Y47.7237 F1200
    G01 X160.8841 F1200
    G01 Y48.4381 F1200
    G01 X147.4200 F1200
    G01 X147.2613 Y48.4203 F1200
    G01 Y49.1114 F1200
    G01 X161.0429 F1200
    G01 Y47.0826 F1200
    G01 X150.5357 F1200
    G03 X149.7420 Y46.2889 I0.0000 J-0.7937 F1200
    G01 Y41.7684 F1200
    G03 X150.5357 Y40.9747 I0.7937 J0.0000 F1200
    G01 X160.1388 F1200
    G01 Y38.9459 F1200
    G01 X150.5357 F1200
    G03 X149.7420 Y38.1521 I0.0000 J-0.7937 F1200
    G01 Y32.7279 F1200
    G03 X150.5357 Y31.9342 I0.7937 J0.0000 F1200
    G01 X161.4948 F1200
    G01 Y29.9053 F1200
    G01 X147.2613 F1200
    G01 Y48.4203 F1200
    G01 X147.4200 Y48.4381 F1200
    G00 Z4.0000 F480
    ;No. 6: Hole 5
    G00 X157.7814 Y58.9478 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X166.3512 F1200
    G01 Y59.6622 F1200
    G01 X157.7814 F1200
    G01 Y60.3766 F1200
    G01 X166.3512 F1200
    G01 X164.3724 F1200
    G01 Y61.0910 F1200
    G01 X159.7813 F1200
    G01 X159.8464 Y61.8053 F1200
    G01 X164.3073 F1200
    G01 Y62.5197 F1200
    G01 X159.8464 F1200
    G01 Y63.2341 F1200
    G01 X164.3073 F1200
    G01 Y63.9485 F1200
    G01 X159.8464 F1200
    G01 Y64.6628 F1200
    G01 X164.3073 F1200
    G01 Y65.3772 F1200
    G01 X159.8464 F1200
    G01 Y66.0916 F1200
    G01 X164.3073 F1200
    G01 Y66.8060 F1200
    G01 X159.8464 F1200
    G01 X159.7279 Y67.5203 F1200
    G01 X164.4362 F1200
    G01 X164.8213 Y68.2347 F1200
    G01 X159.3522 F1200
    G01 X158.9765 Y68.9491 F1200
    G01 X165.2065 F1200
    G01 X165.5917 Y69.6635 F1200
    G01 X158.6008 F1200
    G01 X158.2251 Y70.3778 F1200
    G01 X165.9769 F1200
    G01 X166.3620 Y71.0922 F1200
    G01 X157.8494 F1200
    G01 X157.4737 Y71.8066 F1200
    G01 X161.4955 F1200
    G01 X161.0474 Y72.5210 F1200
    G01 X157.0980 F1200
    G01 X156.7223 Y73.2353 F1200
    G01 X160.6841 F1200
    G01 X160.3208 Y73.9497 F1200
    G01 X156.3466 F1200
    G01 X155.9709 Y74.6641 F1200
    G01 X159.9575 F1200
    G01 X159.5942 Y75.3785 F1200
    G01 X155.5952 F1200
    G01 X155.2195 Y76.0928 F1200
    G01 X159.2309 F1200
    G01 X158.8677 Y76.8072 F1200
    G01 X154.8439 F1200
    G01 X154.4682 Y77.5216 F1200
    G01 X158.5044 F1200
    G01 X158.1411 Y78.2360 F1200
    G01 X154.0925 F1200
    G01 X153.7168 Y78.9503 F1200
    G01 X157.7791 F1200
    G01 X157.7524 Y79.6647 F1200
    G01 X153.3411 F1200
    G01 Y80.3791 F1200
    G01 X150.8146 F1200
    G01 X159.3935 F1200
    G01 Y81.0935 F1200
    G01 X150.8146 F1200
    G01 Y81.8078 F1200
    G01 X159.3935 F1200
    G00 Z4.0000 F480
    G00 X162.7225 Y71.0922 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y71.8066 F1200
    G01 X166.7472 F1200
    G01 X167.1324 Y72.5210 F1200
    G01 X163.1659 F1200
    G01 X163.5215 Y73.2353 F1200
    G01 X167.5176 F1200
    G01 X167.9027 Y73.9497 F1200
    G01 X163.8771 F1200
    G01 X164.2327 Y74.6641 F1200
    G01 X168.2879 F1200
    G01 X168.6731 Y75.3785 F1200
    G01 X164.5884 F1200
    G01 X164.9440 Y76.0928 F1200
    G01 X169.0583 F1200
    G01 X169.4435 Y76.8072 F1200
    G01 X165.2996 F1200
    G01 X165.6552 Y77.5216 F1200
    G01 X169.8287 F1200
    G01 X170.2139 Y78.2360 F1200
    G01 X166.0109 F1200
    G01 X166.3655 Y78.9503 F1200
    G01 X170.5991 F1200
    G01 X170.9843 Y79.6647 F1200
    G01 X166.3924 F1200
    G01 Y80.3791 F1200
    G01 X164.8230 F1200
    G01 X173.1066 F1200
    G01 Y81.0935 F1200
    G01 X164.8230 F1200
    G01 Y81.8078 F1200
    G01 X173.1066 F1200
    G01 X173.2653 Y81.8293 F1200
    G01 Y81.6094 F1200
    G01 Y81.2313 F1200
    G01 Y80.8532 F1200
    G01 Y80.4751 F1200
    G01 Y80.2761 F1200
    G01 Y80.1346 F1200
    G01 X173.1922 F1200
    G01 X173.0838 F1200
    G01 X172.7587 F1200
    G01 X172.6504 F1200
    G01 X172.5420 F1200
    G01 X172.3253 F1200
    G01 X172.2169 F1200
    G01 X172.1086 F1200
    G03 X171.2377 Y79.7905 I-0.1659 J-0.8542 F1200
    G03 X170.8616 Y79.1026 I6.1970 J-3.8354 F1200
    G01 X170.5300 Y78.4876 F1200
    G01 X170.1983 Y77.8726 F1200
    G01 X169.8667 Y77.2576 F1200
    G01 X169.5351 Y76.6426 F1200
    G01 X169.2035 Y76.0276 F1200
    G01 X168.8719 Y75.4126 F1200
    G01 X168.5403 Y74.7976 F1200
    G01 X168.2087 Y74.1826 F1200
    G01 X167.8771 Y73.5676 F1200
    G01 X167.5455 Y72.9526 F1200
    G01 X167.2139 Y72.3376 F1200
    G01 X166.8823 Y71.7226 F1200
    G01 X166.5507 Y71.1076 F1200
    G01 X166.2191 Y70.4926 F1200
    G01 X165.8875 Y69.8776 F1200
    G01 X165.5559 Y69.2626 F1200
    G01 X165.2243 Y68.6476 F1200
    G03 X164.5325 Y67.3588 I15.2829 J-9.0339 F1200
    G03 X164.4661 Y67.0409 I0.7273 J-0.3179 F1200
    G01 Y63.6781 F1200
    G01 Y63.3979 F1200
    G01 Y62.8374 F1200
    G01 Y62.5572 F1200
    G01 Y62.2770 F1200
    G01 Y61.9967 F1200
    G03 X164.4746 Y61.3198 I3.4979 J-0.2941 F1200
    G03 X165.2598 Y60.6425 I0.7852 J0.1165 F1200
    G01 X166.0774 F1200
    G01 X166.1796 F1200
    G01 X166.2818 F1200
    G01 X166.3840 F1200
    G01 X166.3940 F1200
    G01 X166.4962 F1200
    G01 X166.5100 F1200
    G01 Y59.5351 F1200
    G01 Y59.1548 F1200
    G01 Y58.7746 F1200
    G01 Y58.4277 F1200
    G01 X166.2563 F1200
    G01 X165.7325 F1200
    G01 X161.0189 F1200
    G01 X159.9714 F1200
    G01 X159.4476 F1200
    G01 X158.9239 F1200
    G01 X158.4001 F1200
    G01 X157.8664 F1200
    G01 X157.6226 F1200
    G01 Y59.5351 F1200
    G01 Y59.9153 F1200
    G01 Y60.3056 F1200
    G01 Y60.6425 F1200
    G01 X157.6549 F1200
    G01 X157.7581 F1200
    G01 X157.8614 F1200
    G01 X157.9646 F1200
    G01 X158.1711 F1200
    G01 X158.3776 F1200
    G01 X158.4809 F1200
    G01 X158.5841 F1200
    G03 X159.3020 Y60.7554 I0.2020 J1.0539 F1200
    G03 X159.6877 Y61.4363 I-0.4081 J0.6808 F1200
    G01 Y62.5610 F1200
    G01 Y63.1233 F1200
    G01 Y63.6856 F1200
    G01 Y64.2480 F1200
    G01 Y64.8103 F1200
    G01 Y65.3726 F1200
    G01 Y65.9350 F1200
    G01 Y66.2162 F1200
    G01 Y66.4973 F1200
    G03 X159.6819 Y67.1555 I-4.1282 J0.2927 F1200
    G03 X159.5965 Y67.4292 I-0.7879 J-0.0958 F1200
    G01 X159.2735 Y68.0432 F1200
    G01 X158.9506 Y68.6573 F1200
    G01 X158.6276 Y69.2713 F1200
    G01 X158.3047 Y69.8854 F1200
    G01 X157.9818 Y70.4994 F1200
    G01 X157.6588 Y71.1135 F1200
    G01 X157.3359 Y71.7276 F1200
    G01 X157.0130 Y72.3416 F1200
    G01 X156.7271 Y72.8851 F1200
    G01 X156.0441 Y74.1838 F1200
    G01 X155.7212 Y74.7979 F1200
    G01 X155.3983 Y75.4119 F1200
    G01 X155.0753 Y76.0260 F1200
    G01 X154.7524 Y76.6401 F1200
    G01 X154.4295 Y77.2541 F1200
    G01 X154.1065 Y77.8682 F1200
    G01 X153.7836 Y78.4822 F1200
    G03 X153.1014 Y79.7723 I-14.5781 J-6.8829 F1200
    G03 X152.4352 Y80.1346 I-0.6662 J-0.4315 F1200
    G01 X152.0492 F1200
    G01 X151.9205 F1200
    G01 X151.6632 F1200
    G01 X151.4059 F1200
    G01 X151.2773 F1200
    G01 X150.8914 F1200
    G01 X150.7627 F1200
    G01 X150.7527 F1200
    G01 X150.6559 F1200
    G01 Y81.2313 F1200
    G01 Y81.4204 F1200
    G01 Y81.9975 F1200
    G01 Y82.3280 F1200
    G01 X152.4831 F1200
    G01 X153.0073 F1200
    G01 X153.5315 F1200
    G01 X155.1040 F1200
    G01 X155.6282 F1200
    G01 X156.6766 F1200
    G01 X157.2008 F1200
    G01 X158.2492 F1200
    G01 X158.7834 F1200
    G01 X159.2876 F1200
    G01 X159.3076 F1200
    G01 X159.5522 F1200
    G01 Y81.4204 F1200
    G01 Y81.2313 F1200
    G01 Y80.8532 F1200
    G01 Y80.4751 F1200
    G01 Y80.4651 F1200
    G01 Y80.1346 F1200
    G01 X159.3270 F1200
    G01 X159.2421 F1200
    G01 X159.1572 F1200
    G01 X158.9874 F1200
    G01 X158.9025 F1200
    G01 X158.8177 F1200
    G03 X157.9403 Y78.9811 I-0.1524 J-0.7944 F1200
    G01 X158.1134 Y78.6408 F1200
    G01 X158.2864 Y78.3005 F1200
    G01 X158.4595 Y77.9602 F1200
    G01 X158.6325 Y77.6199 F1200
    G01 X158.8055 Y77.2796 F1200
    G01 X158.9786 Y76.9393 F1200
    G01 X159.1516 Y76.5991 F1200
    G01 X159.3247 Y76.2587 F1200
    G01 X159.4977 Y75.9184 F1200
    G01 X159.6708 Y75.5781 F1200
    G01 X159.8438 Y75.2378 F1200
    G01 X160.0169 Y74.8975 F1200
    G01 X160.1899 Y74.5572 F1200
    G01 X160.3630 Y74.2169 F1200
    G01 X160.5360 Y73.8766 F1200
    G01 X160.7091 Y73.5363 F1200
    G01 X160.8822 Y73.1960 F1200
    G01 X161.0552 Y72.8557 F1200
    G03 X161.4410 Y72.1060 I7.6514 J3.4633 F1200
    G03 X162.8195 Y72.1813 I0.6679 J0.4290 F1200
    G01 X162.9889 Y72.5216 F1200
    G01 X163.1582 Y72.8618 F1200
    G01 X163.3276 Y73.2021 F1200
    G01 X163.4970 Y73.5424 F1200
    G01 X163.6664 Y73.8827 F1200
    G01 X163.8358 Y74.2230 F1200
    G01 X164.0052 Y74.5633 F1200
    G01 X164.1746 Y74.9036 F1200
    G01 X164.3440 Y75.2439 F1200
    G01 X164.4832 Y75.5233 F1200
    G01 X164.6829 Y75.9245 F1200
    G01 X164.8523 Y76.2648 F1200
    G01 X165.0217 Y76.6051 F1200
    G01 X165.1911 Y76.9454 F1200
    G01 X165.3605 Y77.2857 F1200
    G01 X165.5299 Y77.6260 F1200
    G01 X165.6993 Y77.9663 F1200
    G01 X165.8687 Y78.3066 F1200
    G03 X166.2397 Y79.0611 I-7.2315 J4.0243 F1200
    G03 X165.4969 Y80.1346 I-0.7428 J0.2798 F1200
    G01 X165.2529 F1200
    G01 X165.1716 F1200
    G01 X165.0090 F1200
    G01 X164.8463 F1200
    G01 X164.7650 F1200
    G01 X164.7550 F1200
    G01 X164.6937 F1200
    G01 X164.6642 F1200
    G01 Y80.4751 F1200
    G01 Y80.8532 F1200
    G01 Y81.2313 F1200
    G01 Y81.6094 F1200
    G01 Y81.9875 F1200
    G01 Y82.1766 F1200
    G01 Y82.1866 F1200
    G01 Y82.3280 F1200
    G01 X166.4176 F1200
    G01 X166.9271 F1200
    G01 X167.4365 F1200
    G01 X168.9648 F1200
    G01 X169.4742 F1200
    G01 X171.0025 F1200
    G01 X172.0213 F1200
    G01 X172.5408 F1200
    G01 X173.0302 F1200
    G01 X173.0502 F1200
    G01 X173.2653 F1200
    G01 Y82.1766 F1200
    G01 Y81.8293 F1200
    G01 X173.1066 Y81.8078 F1200
    G00 Z4.0000 F480
    ;No. 7: Hole 4
    G00 X145.3888 Y81.8077 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X136.8301 F1200
    G01 Y81.0933 F1200
    G01 X145.3888 F1200
    G01 Y80.3790 F1200
    G01 X136.8301 F1200
    G01 X138.5878 F1200
    G01 Y79.6646 F1200
    G01 X143.1777 F1200
    G01 X142.9385 Y78.9502 F1200
    G01 X138.5660 F1200
    G01 X138.3284 Y78.2358 F1200
    G01 X142.6998 F1200
    G01 X142.4611 Y77.5215 F1200
    G01 X138.0909 F1200
    G01 X137.8533 Y76.8071 F1200
    G01 X142.2224 F1200
    G01 X141.9837 Y76.0927 F1200
    G01 X137.6146 F1200
    G01 X137.3761 Y75.3783 F1200
    G01 X141.7450 F1200
    G01 X141.5063 Y74.6640 F1200
    G01 X137.1388 F1200
    G01 X136.9029 Y73.9496 F1200
    G01 X141.2676 F1200
    G01 X141.0289 Y73.2352 F1200
    G01 X136.6629 F1200
    G01 X136.4194 Y72.5208 F1200
    G01 X140.7902 F1200
    G01 X140.5515 Y71.8065 F1200
    G01 X136.1771 F1200
    G01 X135.9365 Y71.0921 F1200
    G01 X140.3128 F1200
    G01 X140.0740 Y70.3777 F1200
    G01 X135.6975 F1200
    G01 X135.4604 Y69.6633 F1200
    G01 X139.8353 F1200
    G01 X139.5966 Y68.9490 F1200
    G01 X135.2255 F1200
    G01 X134.9929 Y68.2346 F1200
    G01 X139.3579 F1200
    G01 X139.1192 Y67.5202 F1200
    G01 X134.7623 F1200
    G01 X134.5320 Y66.8058 F1200
    G01 X138.8805 F1200
    G01 X138.6418 Y66.0915 F1200
    G01 X134.2761 F1200
    G01 Y65.3771 F1200
    G01 X138.4031 F1200
    G01 X128.4928 F1200
    G01 X128.7326 Y64.6627 F1200
    G01 X138.1643 F1200
    G01 X137.9256 Y63.9483 F1200
    G01 X128.9723 F1200
    G01 X129.2121 Y63.2340 F1200
    G01 X137.6869 F1200
    G01 X137.4482 Y62.5196 F1200
    G01 X129.4518 F1200
    G01 X129.6916 Y61.8052 F1200
    G01 X137.2095 F1200
    G01 X136.9708 Y61.0908 F1200
    G01 X129.9314 F1200
    G01 X130.1711 Y60.3765 F1200
    G01 X136.7320 F1200
    G01 X136.4933 Y59.6621 F1200
    G01 X130.4109 F1200
    G01 X130.6506 Y58.9477 F1200
    G01 X136.2546 F1200
    G00 Z4.0000 F480
    G00 X132.6398 Y65.3771 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y66.0915 F1200
    G01 X128.2530 F1200
    G01 X128.0133 Y66.8058 F1200
    G01 X132.3742 F1200
    G01 X132.1307 Y67.5202 F1200
    G01 X127.7735 F1200
    G01 X127.5338 Y68.2346 F1200
    G01 X131.8879 F1200
    G01 X131.6473 Y68.9490 F1200
    G01 X127.2940 F1200
    G01 X127.0542 Y69.6633 F1200
    G01 X131.4082 F1200
    G01 X131.1700 Y70.3777 F1200
    G01 X126.8145 F1200
    G01 X126.5747 Y71.0921 F1200
    G01 X130.9321 F1200
    G01 X130.6951 Y71.8065 F1200
    G01 X126.3350 F1200
    G01 X126.0952 Y72.5208 F1200
    G01 X130.4571 F1200
    G01 X130.2174 Y73.2352 F1200
    G01 X125.8554 F1200
    G01 X125.6157 Y73.9496 F1200
    G01 X129.9764 F1200
    G01 X129.7357 Y74.6640 F1200
    G01 X125.3759 F1200
    G01 X125.1362 Y75.3783 F1200
    G01 X129.4952 F1200
    G01 X129.2553 Y76.0927 F1200
    G01 X124.8964 F1200
    G01 X124.6567 Y76.8071 F1200
    G01 X129.0165 F1200
    G01 X128.7795 Y77.5215 F1200
    G01 X124.4169 F1200
    G01 X124.1772 Y78.2358 F1200
    G01 X128.5450 F1200
    G01 X128.3123 Y78.9502 F1200
    G01 X123.9374 F1200
    G01 X123.6971 Y79.6646 F1200
    G01 X128.2910 F1200
    G01 Y80.3790 F1200
    G01 X130.0451 F1200
    G01 X121.4863 F1200
    G01 Y81.0933 F1200
    G01 X130.0451 F1200
    G01 Y81.8077 F1200
    G01 X121.4863 F1200
    G01 X121.3276 Y81.8060 F1200
    G01 Y81.9975 F1200
    G01 X121.3284 Y82.3280 F1200
    G01 X123.1496 F1200
    G01 X123.6728 F1200
    G01 X124.1960 F1200
    G01 X125.7656 F1200
    G01 X126.2888 F1200
    G01 X127.3352 F1200
    G01 X127.8584 F1200
    G01 X128.9048 F1200
    G01 X129.4380 F1200
    G01 X129.9412 F1200
    G01 X129.9612 F1200
    G01 X130.2038 F1200
    G01 Y81.9876 F1200
    G01 Y81.6095 F1200
    G01 Y81.2314 F1200
    G01 Y80.8533 F1200
    G01 Y80.4752 F1200
    G01 Y80.2762 F1200
    G01 Y80.1346 F1200
    G01 X130.1827 F1200
    G01 X129.9111 F1200
    G01 X129.8205 F1200
    G01 X129.7300 F1200
    G01 X129.5489 F1200
    G01 X129.4584 F1200
    G01 X129.3678 F1200
    G03 X128.4029 Y79.2163 I-0.1574 J-0.8007 F1200
    G03 X132.7557 Y66.2086 I1118.8492 J367.1778 F1200
    G03 X134.2653 Y66.4960 I0.7091 J0.3839 F1200
    G01 X134.2913 Y66.5765 F1200
    G01 X134.3172 Y66.6570 F1200
    G01 X134.3432 Y66.7375 F1200
    G01 X134.3691 Y66.8180 F1200
    G01 X134.3951 Y66.8985 F1200
    G01 X134.4210 Y66.9790 F1200
    G01 X134.4470 Y67.0595 F1200
    G01 X134.4730 Y67.1400 F1200
    G01 X134.4989 Y67.2205 F1200
    G02 X137.8164 Y77.1992 I2511.9960 J-829.5917 F1200
    G01 X137.8557 Y77.3173 F1200
    G01 X137.8950 Y77.4355 F1200
    G01 X137.9343 Y77.5537 F1200
    G01 X137.9736 Y77.6720 F1200
    G01 X138.0129 Y77.7902 F1200
    G01 X138.0524 Y77.9090 F1200
    G01 X138.0915 Y78.0266 F1200
    G01 X138.1309 Y78.1448 F1200
    G01 X138.1702 Y78.2630 F1200
    G01 X138.2095 Y78.3812 F1200
    G01 X138.2488 Y78.4994 F1200
    G03 X138.4810 Y79.2531 I-3.4554 J1.4770 F1200
    G03 X137.6921 Y80.1346 I-0.7889 J0.0877 F1200
    G01 X137.4199 F1200
    G01 X137.3292 F1200
    G01 X137.1477 F1200
    G01 X136.9663 F1200
    G01 X136.8755 F1200
    G01 X136.8655 F1200
    G01 X136.7748 F1200
    G01 X136.6713 F1200
    G01 Y80.8532 F1200
    G01 Y81.2313 F1200
    G01 Y81.6094 F1200
    G01 Y81.9975 F1200
    G01 Y82.3280 F1200
    G01 X138.4934 F1200
    G01 X139.0166 F1200
    G01 X139.5398 F1200
    G01 X141.1093 F1200
    G01 X141.6325 F1200
    G01 X142.6789 F1200
    G01 X143.2021 F1200
    G01 X144.2485 F1200
    G01 X144.7817 F1200
    G01 X145.2849 F1200
    G01 X145.3049 F1200
    G01 X145.5476 F1200
    G01 Y81.9875 F1200
    G01 Y81.6094 F1200
    G01 Y81.2313 F1200
    G01 Y80.8532 F1200
    G01 Y80.4751 F1200
    G01 Y80.1346 F1200
    G01 X145.4341 F1200
    G01 X145.3207 F1200
    G01 X144.9805 F1200
    G01 X144.8671 F1200
    G01 X144.7537 F1200
    G01 X144.5269 F1200
    G01 X144.4135 F1200
    G01 X144.3001 F1200
    G03 X143.4594 Y79.8440 I-0.1707 J-0.8675 F1200
    G03 X143.3205 Y79.5924 I0.6139 J-0.5031 F1200
    G01 X142.9578 Y78.5070 F1200
    G01 X142.5951 Y77.4217 F1200
    G01 X142.2325 Y76.3363 F1200
    G01 X141.8698 Y75.2510 F1200
    G01 X141.5071 Y74.1656 F1200
    G01 X141.1445 Y73.0802 F1200
    G01 X140.7818 Y71.9949 F1200
    G01 X140.4191 Y70.9095 F1200
    G01 X140.0565 Y69.8242 F1200
    G01 X139.6938 Y68.7388 F1200
    G01 X139.3311 Y67.6535 F1200
    G01 X138.9684 Y66.5681 F1200
    G01 X138.6058 Y65.4828 F1200
    G01 X138.2431 Y64.3974 F1200
    G01 X137.8804 Y63.3121 F1200
    G01 X137.5177 Y62.2267 F1200
    G01 X137.1550 Y61.1413 F1200
    G01 X136.7923 Y60.0560 F1200
    G01 X136.4296 Y58.9706 F1200
    G01 X136.2481 Y58.4274 F1200
    G01 X134.1266 F1200
    G01 X133.4533 F1200
    G01 X133.1167 F1200
    G01 X132.7800 F1200
    G01 X132.4434 F1200
    G01 X132.1067 F1200
    G01 X131.7701 F1200
    G01 X131.4334 F1200
    G01 X131.0968 F1200
    G01 X130.7502 F1200
    G01 X130.6578 F1200
    G01 X130.4751 Y58.9716 F1200
    G01 X130.1109 Y60.0569 F1200
    G01 X129.7466 Y61.1423 F1200
    G01 X129.3824 Y62.2277 F1200
    G01 X129.0181 Y63.3130 F1200
    G01 X128.6538 Y64.3984 F1200
    G01 X128.2896 Y65.4838 F1200
    G01 X127.9253 Y66.5691 F1200
    G01 X127.5610 Y67.6545 F1200
    G01 X126.8325 Y69.8252 F1200
    G01 X126.4682 Y70.9105 F1200
    G01 X126.1039 Y71.9959 F1200
    G01 X125.7397 Y73.0812 F1200
    G01 X125.3754 Y74.1666 F1200
    G01 X125.0111 Y75.2520 F1200
    G01 X124.6469 Y76.3373 F1200
    G01 X124.2826 Y77.4227 F1200
    G03 X123.5400 Y79.6322 I-42.8888 J-13.1861 F1200
    G03 X122.8016 Y80.1346 I-0.7384 J-0.2913 F1200
    G01 X122.4614 F1200
    G01 X122.3480 F1200
    G01 X122.1213 F1200
    G01 X121.8945 F1200
    G01 X121.7811 F1200
    G01 X121.4409 F1200
    G01 X121.3276 F1200
    G01 Y80.2861 F1200
    G01 Y80.8532 F1200
    G01 Y81.2313 F1200
    G01 Y81.4204 F1200
    G01 Y81.6094 F1200
    G01 Y81.8060 F1200
    G01 X121.4863 Y81.8077 F1200
    G00 Z4.0000 F480
    ;No. 8: Hole 13
    G00 X115.1930 Y79.6647 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X105.5853 F1200
    G01 X105.3707 Y78.9503 F1200
    G01 X115.4072 F1200
    G01 X115.6213 Y78.2360 F1200
    G01 X111.2727 F1200
    G01 X111.4937 Y77.5216 F1200
    G01 X115.8355 F1200
    G01 X116.0497 Y76.8072 F1200
    G01 X111.7061 F1200
    G01 X111.9184 Y76.0928 F1200
    G01 X116.2638 F1200
    G01 X116.4780 Y75.3785 F1200
    G01 X112.1308 F1200
    G01 X112.3431 Y74.6641 F1200
    G01 X116.6922 F1200
    G01 X116.9063 Y73.9497 F1200
    G01 X112.5555 F1200
    G01 X112.7679 Y73.2353 F1200
    G01 X117.1205 F1200
    G01 X117.3347 Y72.5210 F1200
    G01 X112.9802 F1200
    G01 X113.1926 Y71.8066 F1200
    G01 X117.5488 F1200
    G01 X117.7630 Y71.0922 F1200
    G01 X113.4049 F1200
    G01 X113.6173 Y70.3778 F1200
    G01 X117.9772 F1200
    G01 X118.1913 Y69.6635 F1200
    G01 X113.8296 F1200
    G01 X114.0420 Y68.9491 F1200
    G01 X118.4055 F1200
    G01 X118.6197 Y68.2347 F1200
    G01 X114.1035 F1200
    G01 Y67.5203 F1200
    G01 X118.8338 F1200
    G01 X101.9377 F1200
    G01 X102.1523 Y68.2347 F1200
    G01 X106.6742 F1200
    G01 X106.7362 Y68.9491 F1200
    G01 X102.3668 F1200
    G01 X102.5814 Y69.6635 F1200
    G01 X106.9507 F1200
    G01 X107.1653 Y70.3778 F1200
    G01 X102.7960 F1200
    G01 X103.0105 Y71.0922 F1200
    G01 X107.3798 F1200
    G01 X107.5944 Y71.8066 F1200
    G01 X103.2251 F1200
    G01 X103.4396 Y72.5210 F1200
    G01 X107.8090 F1200
    G01 X108.0235 Y73.2353 F1200
    G01 X103.6542 F1200
    G01 X103.8687 Y73.9497 F1200
    G01 X108.2381 F1200
    G01 X108.4527 Y74.6641 F1200
    G01 X104.0833 F1200
    G01 X104.2979 Y75.3785 F1200
    G01 X108.6672 F1200
    G01 X108.8818 Y76.0928 F1200
    G01 X104.5124 F1200
    G01 X104.7270 Y76.8072 F1200
    G01 X109.0963 F1200
    G01 X109.3109 Y77.5216 F1200
    G01 X104.9416 F1200
    G01 X105.1561 Y78.2360 F1200
    G01 X109.5338 F1200
    G01 X109.6803 Y78.1745 F1200
    G03 X109.5025 Y77.6076 I2.8654 J-1.2105 F1200
    G01 X109.3619 Y77.1397 F1200
    G01 X109.2214 Y76.6717 F1200
    G01 X109.0809 Y76.2038 F1200
    G01 X108.9403 Y75.7358 F1200
    G01 X108.7998 Y75.2679 F1200
    G01 X108.6592 Y74.7999 F1200
    G01 X108.5187 Y74.3320 F1200
    G01 X108.3781 Y73.8640 F1200
    G01 X108.2310 Y73.3744 F1200
    G01 X108.0970 Y72.9281 F1200
    G01 X107.9564 Y72.4602 F1200
    G01 X107.8159 Y71.9922 F1200
    G01 X107.6753 Y71.5242 F1200
    G01 X107.5348 Y71.0563 F1200
    G01 X107.3942 Y70.5883 F1200
    G01 X107.2537 Y70.1204 F1200
    G01 X107.1132 Y69.6524 F1200
    G03 X106.8126 Y68.6368 I9.6558 J-3.4100 F1200
    G03 X107.5923 Y67.6944 I0.7797 J-0.1486 F1200
    G01 X108.1516 F1200
    G01 X108.7108 F1200
    G01 X110.1091 F1200
    G01 X110.3887 F1200
    G01 X110.6683 F1200
    G01 X110.9480 F1200
    G01 X111.2277 F1200
    G01 X111.5073 F1200
    G01 X111.7870 F1200
    G01 X112.0666 F1200
    G01 X112.3463 F1200
    G03 X113.2672 Y67.6987 I0.4195 J8.9072 F1200
    G03 X113.9462 Y68.7144 I-0.0819 J0.7895 F1200
    G01 X113.7552 Y69.3568 F1200
    G01 X113.4875 Y70.2574 F1200
    G01 X113.3202 Y70.8201 F1200
    G01 X113.2405 Y71.0882 F1200
    G01 X113.1191 Y71.4968 F1200
    G01 X113.0973 Y71.5698 F1200
    G01 X112.8713 Y72.3303 F1200
    G01 X112.7318 Y72.7994 F1200
    G01 X112.6503 Y73.0736 F1200
    G01 X112.4254 Y73.8301 F1200
    G01 X112.2862 Y74.2986 F1200
    G01 X112.1853 Y74.6380 F1200
    G01 X112.0094 Y75.2297 F1200
    G01 X111.8502 Y75.7652 F1200
    G01 X111.7179 Y76.2102 F1200
    G01 X111.5888 Y76.6446 F1200
    G01 X111.4771 Y77.0205 F1200
    G03 X111.1356 Y78.1532 I-10.7757 J-2.6302 F1200
    G03 X109.6803 Y78.1745 I-0.7323 J-0.3057 F1200
    G01 X109.5338 Y78.2360 F1200
    G01 X105.7998 Y80.3791 F1200
    G01 X114.9788 F1200
    G01 X114.7646 Y81.0935 F1200
    G01 X106.0144 F1200
    G01 X106.2289 Y81.8078 F1200
    G01 X114.5504 F1200
    G00 Z4.0000 F480
    G00 X119.0480 Y66.8060 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X101.7232 F1200
    G01 X101.5086 Y66.0916 F1200
    G01 X119.2622 F1200
    G01 X119.4763 Y65.3772 F1200
    G01 X115.0080 F1200
    G01 X115.3396 Y64.6628 F1200
    G01 X119.6905 F1200
    G01 X119.9047 Y63.9485 F1200
    G01 X115.5544 F1200
    G01 X115.7693 Y63.2341 F1200
    G01 X120.1189 F1200
    G01 X120.3330 Y62.5197 F1200
    G01 X115.9842 F1200
    G01 X116.1991 Y61.8053 F1200
    G01 X120.5472 F1200
    G01 X120.7647 Y61.0910 F1200
    G01 X116.2030 F1200
    G01 Y60.3766 F1200
    G01 X113.9889 F1200
    G01 X122.5576 F1200
    G01 Y59.6622 F1200
    G01 X113.9889 F1200
    G01 Y58.9478 F1200
    G01 X122.5576 F1200
    G00 Z4.0000 F480
    G00 X105.7584 Y66.0916 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y65.3772 F1200
    G01 X101.2940 F1200
    G01 X101.0795 Y64.6628 F1200
    G01 X105.4284 F1200
    G01 X105.2171 Y63.9485 F1200
    G01 X100.8649 F1200
    G01 X100.6504 Y63.2341 F1200
    G01 X105.0057 F1200
    G01 X104.7944 Y62.5197 F1200
    G01 X100.4358 F1200
    G01 X100.2212 Y61.8053 F1200
    G01 X104.5830 F1200
    G01 X104.5796 Y61.0910 F1200
    G01 X100.0033 F1200
    G01 Y60.3766 F1200
    G01 X98.2641 F1200
    G01 X106.8332 F1200
    G01 Y59.6622 F1200
    G01 X98.2641 F1200
    G01 Y58.9478 F1200
    G01 X106.8332 F1200
    G01 X106.9919 Y58.9769 F1200
    G01 Y58.7746 F1200
    G01 Y58.5745 F1200
    G01 Y58.4277 F1200
    G01 X106.7383 F1200
    G01 X106.2146 F1200
    G01 X101.5013 F1200
    G01 X100.4539 F1200
    G01 X99.9302 F1200
    G01 X99.4065 F1200
    G01 X98.8828 F1200
    G01 X98.3491 F1200
    G01 X98.1054 F1200
    G01 Y58.9647 F1200
    G01 Y59.1548 F1200
    G01 Y59.5351 F1200
    G01 Y59.7252 F1200
    G01 Y59.9153 F1200
    G01 Y60.1055 F1200
    G01 Y60.2956 F1200
    G01 Y60.4857 F1200
    G01 Y60.4957 F1200
    G01 Y60.6425 F1200
    G01 X98.1235 F1200
    G01 X98.2137 F1200
    G01 X98.3039 F1200
    G01 X98.4844 F1200
    G01 X98.6648 F1200
    G01 X98.7550 F1200
    G01 X98.8452 F1200
    G03 X99.5895 Y60.7994 I0.1879 J0.9528 F1200
    G03 X99.8760 Y61.2079 I-0.4737 J0.6369 F1200
    G01 X100.2017 Y62.2922 F1200
    G01 X100.5274 Y63.3765 F1200
    G01 X100.8530 Y64.4608 F1200
    G01 X101.1787 Y65.5451 F1200
    G01 X101.5044 Y66.6294 F1200
    G01 X101.8300 Y67.7137 F1200
    G01 X102.1557 Y68.7980 F1200
    G01 X102.4813 Y69.8822 F1200
    G01 X102.8070 Y70.9665 F1200
    G01 X103.1327 Y72.0508 F1200
    G01 X103.4583 Y73.1351 F1200
    G01 X103.7840 Y74.2193 F1200
    G01 X104.1096 Y75.3036 F1200
    G01 X104.4353 Y76.3879 F1200
    G01 X104.7609 Y77.4721 F1200
    G01 X105.0866 Y78.5564 F1200
    G01 X105.4123 Y79.6406 F1200
    G03 X106.2192 Y82.3280 I-3031.0286 J911.5800 F1200
    G01 X108.0092 F1200
    G01 X108.4853 F1200
    G01 X108.9614 F1200
    G01 X110.3897 F1200
    G01 X110.8658 F1200
    G01 X111.8181 F1200
    G01 X112.2942 F1200
    G01 X113.2464 F1200
    G01 X113.7325 F1200
    G01 X114.1886 F1200
    G01 X114.2086 F1200
    G01 X114.5602 F1200
    G01 X114.7157 Y81.8095 F1200
    G01 X115.0407 Y80.7253 F1200
    G01 X115.3658 Y79.6410 F1200
    G01 X115.6909 Y78.5568 F1200
    G01 X116.0159 Y77.4725 F1200
    G01 X116.3410 Y76.3882 F1200
    G01 X116.6661 Y75.3040 F1200
    G01 X116.9911 Y74.2197 F1200
    G01 X117.3162 Y73.1354 F1200
    G01 X117.6413 Y72.0512 F1200
    G01 X117.9663 Y70.9669 F1200
    G01 X118.2914 Y69.8826 F1200
    G01 X118.6164 Y68.7983 F1200
    G01 X118.9415 Y67.7141 F1200
    G01 X119.2666 Y66.6298 F1200
    G01 X119.5916 Y65.5455 F1200
    G01 X119.9167 Y64.4612 F1200
    G01 X120.2418 Y63.3769 F1200
    G03 X120.9052 Y61.1681 I41.7507 J11.3352 F1200
    G03 X121.6522 Y60.6425 I0.7471 J0.2681 F1200
    G01 X122.3954 F1200
    G01 X122.4883 F1200
    G01 X122.5812 F1200
    G01 X122.6741 F1200
    G01 X122.7164 F1200
    G01 Y60.1055 F1200
    G01 Y59.9153 F1200
    G01 Y59.7252 F1200
    G01 Y59.5351 F1200
    G01 Y59.3450 F1200
    G01 Y58.7746 F1200
    G01 Y58.5745 F1200
    G01 Y58.4277 F1200
    G01 X122.4627 F1200
    G01 X121.9390 F1200
    G01 X117.2258 F1200
    G01 X116.1784 F1200
    G01 X115.6547 F1200
    G01 X115.1311 F1200
    G01 X114.6074 F1200
    G01 X114.0737 F1200
    G01 X113.8301 F1200
    G01 Y58.5845 F1200
    G01 Y59.5351 F1200
    G01 Y59.7252 F1200
    G01 Y60.1055 F1200
    G01 Y60.2956 F1200
    G01 Y60.4857 F1200
    G01 Y60.4957 F1200
    G01 Y60.6425 F1200
    G01 X113.9479 F1200
    G01 X114.0619 F1200
    G01 X114.1758 F1200
    G01 X114.2898 F1200
    G01 X114.5177 F1200
    G01 X114.7456 F1200
    G01 X114.8596 F1200
    G01 X114.9735 F1200
    G03 X115.6348 Y60.7096 I0.2127 J1.1966 F1200
    G03 X116.0264 Y61.8285 I-0.3404 J0.7471 F1200
    G01 X115.9771 Y61.9920 F1200
    G01 X115.9279 Y62.1556 F1200
    G01 X115.8787 Y62.3191 F1200
    G01 X115.8296 Y62.4826 F1200
    G01 X115.7804 Y62.6461 F1200
    G01 X115.7312 Y62.8097 F1200
    G01 X115.6820 Y62.9732 F1200
    G01 X115.6328 Y63.1367 F1200
    G01 X115.5836 Y63.3002 F1200
    G01 X115.5344 Y63.4637 F1200
    G01 X115.4853 Y63.6273 F1200
    G01 X115.4361 Y63.7908 F1200
    G01 X115.3869 Y63.9543 F1200
    G01 X115.3377 Y64.1178 F1200
    G01 X115.2886 Y64.2813 F1200
    G01 X115.2394 Y64.4448 F1200
    G01 X115.1902 Y64.6083 F1200
    G03 X114.9815 Y65.1626 I-1.4540 J-0.2310 F1200
    G03 X114.3318 Y65.5005 I-0.6498 J-0.4559 F1200
    G01 X113.5420 F1200
    G01 X111.9626 F1200
    G01 X111.5678 F1200
    G01 X110.3832 F1200
    G01 X109.5935 F1200
    G01 X109.1987 F1200
    G01 X108.8038 F1200
    G01 X108.4090 F1200
    G01 X108.0141 F1200
    G01 X107.6193 F1200
    G03 X106.3500 Y65.4960 I-0.5923 J-11.8613 F1200
    G03 X105.6252 Y64.7685 I0.1014 J-0.8258 F1200
    G01 X105.5768 Y64.6049 F1200
    G01 X105.5285 Y64.4414 F1200
    G01 X105.4801 Y64.2779 F1200
    G01 X105.4317 Y64.1144 F1200
    G01 X105.3833 Y63.9509 F1200
    G01 X105.3349 Y63.7874 F1200
    G01 X105.2866 Y63.6238 F1200
    G01 X105.2382 Y63.4603 F1200
    G01 X105.1898 Y63.2968 F1200
    G01 X105.1414 Y63.1333 F1200
    G01 X105.0930 Y62.9697 F1200
    G01 X105.0447 Y62.8062 F1200
    G01 X104.9963 Y62.6427 F1200
    G01 X104.9479 Y62.4791 F1200
    G01 X104.8995 Y62.3156 F1200
    G01 X104.8511 Y62.1521 F1200
    G01 X104.8028 Y61.9885 F1200
    G03 X104.6736 Y61.4187 I1.3666 J-0.6093 F1200
    G03 X105.4672 Y60.6425 I0.7936 J0.0176 F1200
    G01 X106.3946 F1200
    G01 X106.5105 F1200
    G01 X106.6264 F1200
    G01 X106.7423 F1200
    G01 X106.9742 F1200
    G01 X106.9919 F1200
    G01 Y59.7252 F1200
    G01 Y59.3450 F1200
    G01 Y58.9769 F1200
    G01 X106.8332 Y58.9478 F1200
    G00 Z4.0000 F480
    ;No. 9: Hole 3
    G00 X92.6804 Y58.9481 Z4.0000 F2100
    G00 Z0.5000 F480
    G01 Z0.0000 F360
    G01 Z-1.5000 F360
    G01 X86.9507 F1200
    G01 X86.5398 Y59.6625 F1200
    G01 X92.6804 F1200
    G01 Y60.3769 F1200
    G01 X86.1289 F1200
    G01 X85.7180 Y61.0912 F1200
    G01 X92.6804 F1200
    G01 Y61.8056 F1200
    G01 X85.3071 F1200
    G01 X84.8962 Y62.5200 F1200
    G01 X92.6804 F1200
    G01 Y63.2344 F1200
    G01 X84.4853 F1200
    G01 X84.0744 Y63.9487 F1200
    G01 X92.6804 F1200
    G01 Y64.6631 F1200
    G01 X83.6635 F1200
    G01 X83.2526 Y65.3775 F1200
    G01 X92.6804 F1200
    G01 Y66.0919 F1200
    G01 X82.8417 F1200
    G01 X82.4308 Y66.8062 F1200
    G01 X86.9937 F1200
    G01 X86.4107 Y67.5206 F1200
    G01 X82.0199 F1200
    G01 X81.6090 Y68.2350 F1200
    G01 X85.9974 F1200
    G01 X85.5841 Y68.9494 F1200
    G01 X81.1981 F1200
    G01 X80.7872 Y69.6637 F1200
    G01 X85.1707 F1200
    G01 X84.7574 Y70.3781 F1200
    G01 X80.3763 F1200
    G01 X79.9654 Y71.0925 F1200
    G01 X84.3441 F1200
    G01 X83.9308 Y71.8069 F1200
    G01 X79.5545 F1200
    G01 X79.1436 Y72.5212 F1200
    G01 X83.5174 F1200
    G01 X83.1041 Y73.2356 F1200
    G01 X78.7327 F1200
    G01 X78.1764 Y73.9500 F1200
    G01 X82.6908 F1200
    G01 X82.2774 Y74.6644 F1200
    G01 X72.4202 F1200
    G01 Y73.9500 F1200
    G01 X77.2157 F1200
    G01 X76.7498 F1200
    G01 Y73.2356 F1200
    G01 X72.4202 F1200
    G01 Y72.5212 F1200
    G01 X76.7435 F1200
    G01 Y71.8069 F1200
    G01 X72.4202 F1200
    G01 Y71.0925 F1200
    G01 X76.7435 F1200
    G01 Y70.3781 F1200
    G01 X72.4202 F1200
    G01 Y69.6637 F1200
    G01 X76.7435 F1200
    G01 Y68.9494 F1200
    G01 X72.4202 F1200
    G01 Y68.2350 F1200
    G01 X76.7435 F1200
    G01 Y67.5206 F1200
    G01 X72.4202 F1200
    G01 Y66.8062 F1200
    G01 X76.7435 F1200
    G01 Y66.0919 F1200
    G01 X72.4202 F1200
    G01 Y65.3775 F1200
    G01 X76.7435 F1200
    G01 Y64.6631 F1200
    G01 X72.4202 F1200
    G01 Y63.9487 F1200
    G01 X76.7435 F1200
    G01 Y63.2344 F1200
    G01 X72.4202 F1200
    G01 Y62.5200 F1200
    G01 X76.7435 F1200
    G01 Y61.8056 F1200
    G01 X72.4202 F1200
    G01 X72.3552 Y61.0912 F1200
    G01 X76.8084 F1200
    G01 Y60.3769 F1200
    G01 X78.8720 F1200
    G01 X70.2823 F1200
    G01 Y59.6625 F1200
    G01 X78.8720 F1200
    G01 Y58.9481 F1200
    G01 X70.2823 F1200
    G00 Z4.0000 F480
    G00 X72.4202 Y74.6644 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y75.3787 F1200
    G01 X81.8641 F1200
    G01 X81.4508 Y76.0931 F1200
    G01 X72.4202 F1200
    G01 Y76.8075 F1200
    G01 X81.0375 F1200
    G01 X80.6241 Y77.5219 F1200
    G01 X72.4202 F1200
    G01 Y78.2362 F1200
    G01 X80.2108 F1200
    G01 X79.7975 Y78.9506 F1200
    G01 X72.4202 F1200
    G01 X72.3632 Y79.6650 F1200
    G01 X79.3841 F1200
    G01 X78.9708 Y80.3794 F1200
    G01 X70.3027 F1200
    G01 Y81.0937 F1200
    G01 X78.5575 F1200
    G01 X78.1442 Y81.8081 F1200
    G01 X70.3027 F1200
    G00 Z4.0000 F480
    G00 X87.8791 Y66.0919 F2100
    G00 Z0.5000 F480
    G01 Z-1.5000 F360
    G01 Y66.8062 F1200
    G01 X92.6804 F1200
    G01 Y67.5206 F1200
    G01 X88.3802 F1200
    G01 X88.3891 Y68.2350 F1200
    G01 X92.6804 F1200
    G01 Y68.9494 F1200
    G01 X88.3891 F1200
    G01 Y69.6637 F1200
    G01 X92.6804 F1200
    G01 Y70.3781 F1200
    G01 X88.3891 F1200
    G01 Y71.0925 F1200
    G01 X92.6804 F1200
    G01 Y71.8069 F1200
    G01 X88.3891 F1200
    G01 Y72.5212 F1200
    G01 X92.6804 F1200
    G01 Y73.2356 F1200
    G01 X88.3891 F1200
    G01 Y73.9500 F1200
    G01 X92.6804 F1200
    G01 Y74.6644 F1200
    G01 X88.3891 F1200
    G01 Y75.3787 F1200
    G01 X92.6804 F1200
    G01 Y76.0931 F1200
    G01 X88.3891 F1200
    G01 Y76.8075 F1200
    G01 X92.6804 F1200
    G01 Y77.5219 F1200
    G01 X88.3891 F1200
    G01 Y78.2362 F1200
    G01 X92.6804 F1200
    G01 Y78.9506 F1200
    G01 X88.3891 F1200
    G01 X88.3323 Y79.6650 F1200
    G01 X92.7372 F1200
    G01 Y80.3794 F1200
    G01 X94.8193 F1200
    G01 X86.2502 F1200
    G01 Y81.0937 F1200
    G01 X94.8193 F1200
    G01 Y81.8081 F1200
    G01 X86.2502 F1200
    G01 X86.0914 Y81.7835 F1200
    G01 Y81.9979 F1200
    G01 Y82.3285 F1200
    G01 X90.5347 F1200
    G01 X91.5821 F1200
    G01 X92.6295 F1200
    G01 X93.1532 F1200
    G01 X93.6769 F1200
    G01 X94.2006 F1200
    G01 X94.7243 F1200
    G01 X94.7343 F1200
    G01 X94.9780 F1200
    G01 Y81.6098 F1200
    G01 Y81.4208 F1200
    G01 Y81.2317 F1200
    G01 Y81.0427 F1200
    G01 Y80.8536 F1200
    G01 Y80.6646 F1200
    G01 Y80.4755 F1200
    G01 Y80.2764 F1200
    G01 Y80.1349 F1200
    G01 X94.9161 F1200
    G01 X94.8092 F1200
    G01 X94.7022 F1200
    G01 X94.5953 F1200
    G01 X94.4883 F1200
    G01 X94.3814 F1200
    G01 X94.2744 F1200
    G01 X94.0606 F1200
    G01 X93.9536 F1200
    G01 X93.8467 F1200
    G03 X92.9729 Y79.7821 I-0.1667 J-0.8458 F1200
    G03 X92.8391 Y79.3411 I0.6600 J-0.4410 F1200
    G01 Y77.1705 F1200
    G01 Y76.0851 F1200
    G01 Y68.4877 F1200
    G01 Y66.3170 F1200
    G01 Y64.1462 F1200
    G01 Y61.9756 F1200
    G01 Y60.8902 F1200
    G01 Y59.8049 F1200
    G01 Y58.7195 F1200
    G01 Y58.4279 F1200
    G01 X92.5791 F1200
    G01 X91.8765 F1200
    G01 X91.5253 F1200
    G01 X90.8228 F1200
    G01 X90.1203 F1200
    G01 X89.7690 F1200
    G01 X89.4177 F1200
    G01 X89.0665 F1200
    G01 X88.7152 F1200
    G01 X88.3640 F1200
    G01 X88.0127 F1200
    G01 X87.6615 F1200
    G01 X87.3002 F1200
    G01 X87.0668 F1200
    G01 X86.8501 Y58.8046 F1200
    G01 X86.4046 Y59.5793 F1200
    G01 X85.9590 Y60.3539 F1200
    G01 X85.5134 Y61.1286 F1200
    G01 X85.0678 Y61.9033 F1200
    G01 X84.6223 Y62.6779 F1200
    G01 X84.1767 Y63.4526 F1200
    G01 X83.7311 Y64.2272 F1200
    G01 X83.2855 Y65.0019 F1200
    G01 X82.8400 Y65.7766 F1200
    G01 X82.3944 Y66.5513 F1200
    G01 X81.9488 Y67.3259 F1200
    G01 X81.5032 Y68.1006 F1200
    G01 X81.0576 Y68.8753 F1200
    G01 X80.6120 Y69.6500 F1200
    G01 X80.1664 Y70.4247 F1200
    G01 X79.7208 Y71.1993 F1200
    G01 X79.2752 Y71.9740 F1200
    G03 X78.3632 Y73.5576 I-31.8821 J-17.3077 F1200
    G03 X76.9022 Y73.1277 I-0.6672 J-0.4299 F1200
    G01 Y67.2820 F1200
    G01 Y66.6974 F1200
    G01 Y66.1128 F1200
    G01 Y64.9437 F1200
    G01 Y64.3591 F1200
    G01 Y63.7745 F1200
    G01 Y63.1899 F1200
    G01 Y62.6054 F1200
    G03 X76.9060 Y61.3584 I12.6928 J-0.5846 F1200
    G03 X77.6960 Y60.6425 I0.7899 J0.0778 F1200
    G01 X78.5474 F1200
    G01 X78.6538 F1200
    G01 X78.7602 F1200
    G01 X78.8667 F1200
    G01 X79.0308 F1200
    G01 Y60.4857 F1200
    G01 Y59.9153 F1200
    G01 Y59.5351 F1200
    G01 Y59.3450 F1200
    G01 Y58.7746 F1200
    G01 Y58.5745 F1200
    G01 Y58.4277 F1200
    G01 X78.7750 F1200
    G01 X78.2503 F1200
    G01 X73.5277 F1200
    G01 X72.4783 F1200
    G01 X71.9535 F1200
    G01 X71.4288 F1200
    G01 X70.9041 F1200
    G01 X70.3693 F1200
    G01 X70.1236 F1200
    G01 Y59.9153 F1200
    G01 Y60.1155 F1200
    G01 Y60.4957 F1200
    G01 Y60.6425 F1200
    G01 X70.1851 F1200
    G01 X70.2920 F1200
    G01 X70.3988 F1200
    G01 X70.5057 F1200
    G01 X70.7195 F1200
    G01 X70.9333 F1200
    G01 X71.0401 F1200
    G01 X71.1470 F1200
    G03 X71.8418 Y60.7362 I0.2019 J1.1256 F1200
    G03 X72.2614 Y61.4363 I-0.3742 J0.7000 F1200
    G01 Y68.5981 F1200
    G01 Y70.3886 F1200
    G01 Y71.2838 F1200
    G01 Y73.9695 F1200
    G01 Y74.8647 F1200
    G01 Y78.4456 F1200
    G03 X72.2528 Y79.4573 I-5.1947 J0.4618 F1200
    G03 X71.4677 Y80.1346 I-0.7852 J-0.1165 F1200
    G01 X71.1501 F1200
    G01 X71.0442 F1200
    G01 X70.8325 F1200
    G01 X70.6208 F1200
    G01 X70.5149 F1200
    G01 X70.1873 F1200
    G01 X70.1440 F1200
    G01 Y81.2313 F1200
    G01 Y81.6094 F1200
    G01 Y81.9975 F1200
    G01 Y82.3256 F1200
    G02 X78.0266 Y82.3283 I6.7415 J-8272.1087 F1200
    G01 X78.2450 Y81.9509 F1200
    G01 X78.6926 Y81.1773 F1200
    G01 X79.1402 Y80.4036 F1200
    G01 X79.5878 Y79.6300 F1200
    G01 X80.0354 Y78.8564 F1200
    G01 X80.4830 Y78.0827 F1200
    G01 X80.9306 Y77.3091 F1200
    G01 X81.3782 Y76.5355 F1200
    G01 X81.8258 Y75.7619 F1200
    G01 X82.7211 Y74.2146 F1200
    G01 X83.1687 Y73.4410 F1200
    G01 X83.6163 Y72.6673 F1200
    G01 X84.0639 Y71.8937 F1200
    G01 X84.5115 Y71.1201 F1200
    G01 X84.9591 Y70.3465 F1200
    G01 X85.4067 Y69.5728 F1200
    G01 X85.8543 Y68.7992 F1200
    G03 X86.7704 Y67.2179 I31.8734 J17.4085 F1200
    G03 X88.2303 Y67.6495 I0.6662 J0.4316 F1200
    G01 Y69.4033 F1200
    G01 Y71.7416 F1200
    G01 Y72.3262 F1200
    G01 Y73.4954 F1200
    G01 Y74.6646 F1200
    G01 Y75.8337 F1200
    G01 Y76.4183 F1200
    G01 Y77.0029 F1200
    G01 Y77.5874 F1200
    G03 X88.2294 Y79.3801 I-36.5124 J0.8768 F1200
    G03 X87.4366 Y80.1349 I-0.7928 J-0.0389 F1200
    G01 X87.0089 F1200
    G01 X86.7950 F1200
    G01 X86.5811 F1200
    G01 X86.4742 F1200
    G01 X86.3672 F1200
    G01 X86.2603 F1200
    G01 X86.1433 F1200
    G01 X86.0914 F1200
    G01 Y80.8536 F1200
    G01 Y81.2317 F1200
    G01 Y81.4208 F1200
    G01 Y81.7835 F1200
    G01 X86.2502 Y81.8081 F1200
    G00 Z4.0000 F480
    M05
  • Thanks for the code. The line
    triggered an internal error. Nothing wrong with g-code, just a bug in host. I have fixed it for next release.
  • I have a similar error message:
    System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
    bei RepetierHostExtender.basic.GCodeAnalyzer.arc(Single[] position, Single[] target, Single[] offset, Single radius, Boolean isclockwise, GCode code)
    bei RepetierHostExtender.basic.GCodeAnalyzer.analyzeShort(GCodeShort code)
    bei RepetierHost.view.RepetierEditor.fastLayerUpdate()
    bei RepetierHost.Main.LoadGCodeOrSTL(String file)
    Is this the same problem and when is the new version coming?
    This is my G-Code:
     Made using CamBam - http://www.cambam.co.uk )
    ( Vogelhaus_V0.7 4/11/2022 10:06:30 PM )
    ( Post processor: Default )
    ( T0 : 2.0 )
    G21 G90
    G0 Z3.0
    ( Profil1 Gleichlauf Fräser 2mm 1000mpros )
    G0 X0 Y0 F2000
    S1000
    G0 X93.3455 Y146.1493
    G0 Z1.0
    G1 F1000.0 Z-2.5
    G2 X93.1059 Y146.4073 I0.3768 J0.5899
    G1 X92.676 Y147.2056
    G2 X92.6739 Y147.2096 I0.6163 J0.3319
    G1 X92.2491 Y148.0108
    G2 X92.2475 Y148.0137 I0.6184 J0.3279
    G1 X91.8263 Y148.8171
    G2 X91.8254 Y148.8189 I0.62 J0.325
    G1 X91.4065 Y149.6237
    G2 X91.4061 Y149.6244 I0.6209 J0.3232
    G1 X90.9882 Y150.4295
    G1 X90.5702 Y151.2336
    G1 X90.151 Y152.0356
    G1 X89.7291 Y152.8345
    G1 X89.3033 Y153.6298
    G1 X88.8721 Y154.4204
    G1 X88.4343 Y155.2057
    G1 X87.9884 Y155.9849
    G1 X87.5333 Y156.7571
    G1 X87.0885 Y157.487
    G1 X86.4667 Y158.2571
    G1 X85.7189 Y158.9959
    G2 X85.6781 Y159.0399 I0.492 J0.498
    G1 X84.9786 Y159.861
    G2 X84.9237 Y159.9347 I0.5329 J0.4539
    G1 X84.3418 Y160.8344
    G2 X84.2296 Y161.2146 I0.5878 J0.3801
    G1 Y161.2567
    G1 Y161.4132
    G1 Y161.4758
    G1 Y161.5384
    G1 Y161.6324
    G1 Y161.695
    G1 Y161.8202
    G1 Y161.9454
    G1 Y162.1019
    G1 Y162.2271
    G1 Y162.321
    G1 Y162.4775
    G1 Y162.5715
    G1 Y162.6967
    G1 Y162.8219
    G1 Y162.9471
    G1 Y163.1036
    G1 Y163.2288
    G1 Y163.3853
    G1 Y163.5419
    G2 X84.2609 Y163.7489 I0.7 J0.0
    G1 Y163.7923
    G2 X84.2745 Y163.9296 I0.7 J0.0
    G1 X84.3058 Y164.0861
    G2 X84.3131 Y164.1186 I0.6864 J-0.1373
    G1 X84.3444 Y164.2438
    G1 X84.3669 Y164.334
    G1 X84.3931 Y164.5174
    G1 X84.4244 Y164.7365
    G2 X84.4487 Y164.8445 I0.693 J-0.099
    G1 Y164.8879
    G1 Y164.9818
    G1 Y165.0444
    G1 Y165.1383
    G1 Y165.3575
    G1 Y165.4827
    G1 Y165.6392
    G2 X84.4696 Y165.809 I0.7 J0.0
    G1 X84.48 Y165.8506
    G1 Y165.8896
    G1 Y166.0148
    G1 Y166.0774
    G1 Y166.2966
    G1 Y166.4531
    G1 Y166.5783
    G1 Y166.6722
    G1 Y166.7974
    G1 Y166.8913
    G2 X84.4936 Y167.0286 I0.7 J0.0
    G1 X84.5113 Y167.1172
    G1 Y167.2044
    G1 Y167.267
    G2 X84.5167 Y167.3538 I0.7 J0.0
    G1 X84.5426 Y167.561
    G1 Y167.58
    G2 X84.5635 Y167.7498 I0.7 J0.0
    G1 X84.5739 Y167.7914
    G1 Y167.7991
    G1 Y167.8617
    G2 X84.5948 Y168.0315 I0.7 J0.0
    G1 X84.6052 Y168.0731
    G1 Y168.0809
    G1 Y168.1435
    G2 X84.6791 Y168.4565 I0.7 J0.0
    G2 X84.7211 Y168.599 I0.6887 J-0.1252
    G2 X84.7895 Y168.7692 I0.6781 J-0.1739
    G2 X84.8812 Y168.9218 I0.641 J-0.2814
    G2 X84.9449 Y169.017 I0.6118 J-0.3401
    G2 X85.085 Y169.2261 I0.6421 J-0.2788
    G2 X85.1835 Y169.4087 I0.6585 J-0.2374
    G1 X85.3333 Y169.6084
    G2 X86.1483 Y169.8403 I0.56 J-0.42
    G1 X87.0795 Y169.8111
    G2 X87.4508 Y169.6905 I-0.022 J-0.6997
    G1 X87.3362 Y170.0739
    G1 X87.0648 Y170.8839
    G2 X87.0497 Y170.9355 I0.6637 J0.2223
    G1 X86.8429 Y171.7574
    G2 X86.8227 Y171.8915 I0.6788 J0.1708
    G1 X86.779 Y172.7244
    G2 X86.7991 Y172.9315 I0.699 J0.0367
    G1 X87.0135 Y173.7854
    G2 X87.623 Y174.3115 I0.6789 J-0.1704
    G1 X87.9181 Y174.3409
    G2 X88.1606 Y174.3226 I0.0694 J-0.6965
    G1 X88.438 Y174.2519
    G2 X88.7495 Y174.0787 I-0.1731 J-0.6783
    G1 X88.9973 Y173.841
    G2 X89.1758 Y173.5599 I-0.4846 J-0.5051
    G1 X89.4481 Y172.7541
    G2 X89.4488 Y172.7519 I-0.6632 J-0.2241
    G1 X89.7194 Y171.9424
    G2 X89.7201 Y171.9402 I-0.6639 J-0.2219
    G1 X89.9891 Y171.1269
    G2 X89.9898 Y171.1248 I-0.6646 J-0.2198
    G1 X90.2571 Y170.3077
    G2 X90.2578 Y170.3055 I-0.6653 J-0.2176
    G1 X90.5233 Y169.4846
    G2 X90.524 Y169.4824 I-0.666 J-0.2154
    G1 X90.7878 Y168.6576
    G2 X90.7885 Y168.6554 I-0.6667 J-0.2133
    G1 X91.0506 Y167.8267
    G2 X91.0513 Y167.8246 I-0.6674 J-0.2111
    G1 X91.3117 Y166.9919
    G2 X91.3123 Y166.9897 I-0.6681 J-0.2089
    G1 X91.5709 Y166.1531
    G2 X91.5716 Y166.1509 I-0.6688 J-0.2067
    G1 X91.8283 Y165.3102
    G2 X91.829 Y165.308 I-0.6695 J-0.2045
    G1 X92.084 Y164.4632
    G2 X92.0846 Y164.461 I-0.6701 J-0.2023
    G1 X92.3378 Y163.6122
    G2 X92.3384 Y163.61 I-0.6708 J-0.2
    G1 X92.5897 Y162.757
    G2 X92.5904 Y162.7547 I-0.6715 J-0.1978
    G1 X92.8398 Y161.8976
    G2 X92.8405 Y161.8953 I-0.6721 J-0.1956
    G1 X93.088 Y161.0339
    G2 X93.0886 Y161.0317 I-0.6728 J-0.1933
    G1 X93.3343 Y160.166
    G2 X93.3349 Y160.1638 I-0.6734 J-0.1911
    G1 X93.5787 Y159.2938
    G2 X93.5793 Y159.2916 I-0.674 J-0.1888
    G1 X93.8211 Y158.4173
    G2 X93.8217 Y158.415 I-0.6747 J-0.1866
    G1 X94.0365 Y157.6282
    G1 X94.2624 Y157.2487
    G1 X94.7331 Y156.8334
    G1 X95.2704 Y156.3969
    G2 X95.2708 Y156.3965 I-0.4414 J-0.5433
    G1 X95.8561 Y155.9202
    G1 X96.3772 Y155.6335
    G1 X96.8967 Y155.5058
    G1 X97.4955 Y155.5394
    G1 X98.2543 Y155.7865
    G1 X99.2491 Y156.3342
    G2 X100.2853 Y155.7652 I0.3376 J-0.6132
    G1 X100.3454 Y154.8164
    G2 X100.3456 Y154.8124 I-0.6986 J-0.0443
    G1 X100.3986 Y153.8926
    G1 X100.4598 Y152.9923
    G1 X100.5442 Y152.0974
    G1 X100.667 Y151.1907
    G1 X100.8431 Y150.2541
    G1 X101.0934 Y149.2486
    G2 X101.0481 Y148.7827 I-0.6793 J-0.1691
    G1 X100.6182 Y147.8642
    G2 X100.547 Y147.7447 I-0.634 J0.2967
    G1 X99.9818 Y146.9805
    G2 X99.8445 Y146.8409 I-0.5628 J0.4162
    G1 X99.1054 Y146.2751
    G2 X98.9233 Y146.1746 I-0.4255 J0.5558
    G1 X97.8021 Y145.7589
    G2 X97.7483 Y145.7414 I-0.2434 J0.6563
    G1 X96.6457 Y145.4312
    G2 X96.4829 Y145.4055 I-0.1896 J0.6738
    G1 X95.4278 Y145.3652
    G2 X95.0029 Y145.489 I-0.0267 J0.6995
    G1 X94.5774 Y145.7833
    G1 X94.1595 Y145.9135
    G1 X93.5579 Y146.0588
    G2 X93.3455 Y146.1493 I0.1643 J0.6804
    G1 Z-5.0
    G1 Y161.2567
    G1 Y161.4132
    G1 Y161.4758
    G1 Y161.5384
    G1 Y161.6324
    G1 Y161.695
    G1 Y161.8202
    G1 Y161.9454
    G1 Y162.1019
    G1 Y162.2271
    G1 Y162.321
    G1 Y162.4775
    G1 Y162.5715
    G1 Y162.6967
    G1 Y162.8219
    G1 Y162.9471
    G1 Y163.1036
    G1 Y163.2288
    G1 Y163.3853
    G1 Y163.5419
    G1 Y163.7923
    G1 Y164.8879
    G1 Y164.9818
    G1 Y165.0444
    G1 Y165.1383
    G1 Y165.3575
    G1 Y165.4827
    G1 Y165.6392
    G1 X84.48 Y165.8506
    G1 Y165.8896
    G1 Y166.0148
    G1 Y166.0774
    G1 Y166.2966
    G1 Y166.4531
    G1 Y166.5783
    G1 Y166.6722
    G1 Y166.7974
    G1 Y166.8913
    G1 Y167.2044
    G1 Y167.267
    G1 Y167.58
    G1 Y167.7991
    G1 Y167.8617
    G1 Y168.0809
    G1 Y168.1435
    G1 Z-7.5
    G1 X88.3741 Y155.3109
    G1 X87.9884 Y155.9849 Z-7.2413
    G1 X87.6208 Y156.6085 Z-7.0
    G1 X86.472 Y158.2505
    G1 X86.4667 Y158.2571 Z-7.0028
    G1 X85.7189 Y158.9959 Z-7.3428
    G2 X85.6781 Y159.0399 Z-7.3624 I0.492 J0.498
    G1 X85.407 Y159.3581 Z-7.5
    G1 Y161.2567
    G1 Y161.4132
    G1 Y161.4758
    G1 Y161.5384
    G1 Y161.6324
    G1 Y161.695
    G1 Y161.8202
    G1 Y161.9454
    G1 Y162.1019
    G1 Y162.2271
    G1 Y162.321
    G1 Y162.4775
    G1 Y162.5715
    G1 Y162.6967
    G1 Y162.8219
    G1 Y162.9471
    G1 Y163.1036
    G1 Y163.2288
    G1 Y163.3853
    G1 Y163.5419
    G1 Y163.7923
    G1 Y164.8879
    G1 Y164.9818
    G1 Y165.0444
    G1 Y165.1383
    G1 Y165.3575
    G1 Y165.4827
    G1 Y165.6392
    G1 X84.48 Y165.8506
    G1 Y165.8896
    G1 Y166.0148
    G1 Y166.0774
    G1 Y166.2966
    G1 Y166.4531
    G1 Y166.5783
    G1 Y166.6722
    G1 Y166.7974
    G1 Y166.8913
    G1 Y167.2044
    G1 Y167.267
    G1 Y167.58
    G1 Y167.7991
    G1 Y167.8617
    G1 Y168.0809
    G1 Y168.1435
    G2 X100.2258 Y156.0064 I0.3376 J-0.6132
    G2 X100.2853 Y155.7652 Z-7.4184 I-0.6391 J-0.2855
    G1 X100.3454 Y154.8164 Z-7.1015
    G2 X100.3456 Y154.8124 Z-7.1002 I-0.6986 J-0.0443
    G1 X100.3629 Y154.5123 Z-7.0
    G1 X100.5046 Y152.5173
    G1 X100.5442 Y152.0974 Z-7.1405
    G1 X100.667 Y151.1907 Z-7.4449
    G1 X100.6978 Y151.027 Z-7.5
    G1 Z-10.0
    G1 X87.9884 Y155.9849 Z-8.4477
    G1 X86.4667 Y158.2571 Z-7.0168
    G1 X85.7189 Y158.9959 Z-9.0568
    G2 X85.6781 Y159.0399 Z-9.1745 I0.492 J0.498
    G1 X85.407 Y159.3581 Z-10.0
    G1 Y161.2567
    G1 Y161.4132
    G1 Y161.4758
    G1 Y161.5384
    G1 Y161.6324
    G1 Y161.695
    G1 Y161.8202
    G1 Y161.9454
    G1 Y162.1019
    G1 Y162.2271
    G1 Y162.321
    G1 Y162.4775
    G1 Y162.5715
    G1 Y162.6967
    G1 Y162.8219
    G1 Y162.9471
    G1 Y163.1036
    G1 Y163.2288
    G1 Y163.3853
    G1 Y163.5419
    G1 Y163.7923
    G1 Y164.8879
    G1 Y164.9818
    G1 Y165.0444
    G1 Y165.1383
    G1 Y165.3575
    G1 Y165.4827
    G1 Y165.6392
    G1 X84.48 Y165.8506
    G1 Y165.8896
    G1 Y166.0148
    G1 Y166.0774
    G1 Y166.2966
    G1 Y166.4531
    G1 Y166.5783
    G1 Y166.6722
    G1 Y166.7974
    G1 Y166.8913
    G1 Y167.2044
    G1 Y167.267
    G1 Y167.58
    G1 Y167.7991
    G1 Y167.8617
    G1 Y168.0809
    G1 Y168.1435
    G2 X100.2853 Y155.7652 Z-9.5107 I-0.6391 J-0.2855
    G1 X100.3454 Y154.8164 Z-7.6092
    G2 X100.3456 Y154.8124 Z-7.6011 I-0.6986 J-0.0443
    G1 X100.5442 Y152.0974 Z-7.8433
    G1 X100.667 Y151.1907 Z-9.6691
    G1 X100.6978 Y151.027 Z-10.0
    G0 Z3.0
  • Yes, looks like the same error in arc. Should work in next release.
  • Thanks for the quick reply?
    Is there an interim solution until the next release?
    When will the next release be ready?
  • After next server release is finished I will update host again. Server is hopefully start of may finished, but has many improvements so might delay.
    Interim solution is not using G2/G3 - it is in the analyse of that that it fails. So far no big problem as slicers do not use it. Just with cnc that is a more frequent issue.
    You could also check server which can send gcode independently and does not make arcs - just sends them.
  • I have also milled G2/G3 with CNC using Repetier.
    The following G-code with G2 does not generate an error, where is the difference?
    ( Vogelhaus_V0.7 4/12/2022 9:33:24 PM )
    ( T0 : 2.0 )
    G21 G90
    G0 Z3.0
    ( Profil1 Gleichlauf Fräser 2mm F1000 )
    G0 X0 Y0 F2000
    S1000
    G0 X2.7098 Y2.3827
    G0 Z1.0
    G1 F1000.0 Z-1.0
    G2 X-1.2 Y12.75 I11.7902 J10.3673
    G1 Y270.75
    G2 X14.5 Y286.45 I15.7 J0.0
    G1 X61.7562
    G2 X99.3742 Y270.8681 I0.0 J-53.2
    G1 X190.8742 Y179.3681
    G2 Y104.1319 I-37.6181 J-37.6181
    G1 X99.3742 Y12.6319
    G2 X61.7562 Y-2.95 I-37.6181 J37.6181
    G1 X14.5
    G2 X2.7098 Y2.3827 I0.0 J15.7
    G0 Z3.0
    Thanks for your efforts!
  • The problem are very small arcs < 0.001 rad. These go into a special case that has some missing tests if the position report function is in use or not. That case shortcuts replacing it with a single line. That causes trying to send positions to a null function.
  • Thanks for the tip.
    Solution: Set in the CamBam system at the postprocessor the minmal arc length to 0.001 (before 0,0001), then you get no more error message. If the arc length smaller, its generated a g1-line.
    I will test it this evening at the machine <span>:wink:</span>
  • I have tested it on my machine and it works.
