Start point
I have tripod printer. By gravity the tripod goes without power down to the bed.
So I would like a menu point to send the head of the tripod to a certain point to lay down the head on a holder.
Is something there that I missed?
Can I add that to the menu?
Thanks!
Thanks!
break;
case UI_ACTION_START:
GCode::executeFString(PSTR("G28/nM104 S0/nG90/nG1 Z200/nG1 X-99 Y56/nG1 Z83/M84"));
break;
case UI_ACTION_ZPOSITION_NOTEST:
Printer::setNoDestinationCheck(true);
for uimenu.h I have no idea what to do!!
In that area the entry should be:
UI_MENU_ACTION2C(ui_menu_zpos_fast_notest,UI_ACTION_ZPOSITION_FAST_NOTEST,UI_TEXT_ACTION_ZPOSITION_FAST2);
#endif
UI_MENU_ACTION2C(ui_menu_epos,UI_ACTION_EPOSITION,UI_TEXT_ACTION_EPOSITION_FAST2);
UI_MENU_ACTION2C(ui_menu_start,UI_ACTION_START,"Startpoint");
?ui_menu_start? what should be here?
Thanks for your help!
ui,cpp:
case UI_ACTION_SET_ORIGIN:
if(!allowMoves) return false;
Printer::setOrigin(0, 0, 0);
break;
break;
case UI_ACTION_DEBUG_ECHO:
does that makes sense?
for the uimenu.h I need some help...
in ui.cpp:
(to write all in one line with /n as separation did not work)
//if(!allowMoves) return false;
//Printer::setOrigin(0, 0, 0);
GCode::executeFString(PSTR("G28"));
GCode::executeFString(PSTR("M104 S0"));
GCode::executeFString(PSTR("M140 S0"));
GCode::executeFString(PSTR("G90"));
GCode::executeFString(PSTR("G1 X-99 Y56 Z89"));
GCode::executeFString(PSTR("M84"));
break;
and in ui.menu:
//old call
//UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_quick_origin,UI_TEXT_SET_TO_ORIGIN,UI_ACTION_SET_ORIGIN,0,MENU_MODE_PRINTING)
//new call - Ablage appears now instead of Set Origin in the menu
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_quick_origin,"Ablage",UI_ACTION_SET_ORIGIN,0,MENU_MODE_PRINTING)
if I add in my editor (notepadd++) \r (= CR) to the \n then it works in one line:
example:
#define PAUSE_START_COMMANDS "G28\n\rG90\n\rG1 Z300\n\rG1 X99 Y56"
(oops maybe I am wrong: I have to check again \n or /n ! the example atleast is working)
