3 extruder fan problem, one extruder no problem fan ?
Hy
I will print with a diamond hotend
I need mixing for every color
I succes add a third extruder and mixing but when i have 3 extruder define in configuration.h the fan dont work
If i define just one extruder the fan work
How can i resolve it please
I upload a video for more explain whats hapened
If you need my setup or other ask me
But in repetier host if i run heat on t1 or t2 and t3 all work , the heating do just in the first extruder
I check tha now
Thanks lot of repetier
i thing there are a bug in firmware with mixing
if define that in configuration.h :
#define NUM_EXTRUDER 3
#define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT1_HEATER_PIN HEATER_0_PIN
#define EXT2_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT2_HEATER_PIN HEATER_0_PIN
the fan work, i see a same real temperature for 3 extruder but i loss the heating ( the same low blinking )
if define that :
#define EXT2_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT2_HEATER_PIN HEATER_2_PIN
and modifie my pins.h
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define HEATER_2_PIN 10 //9
#define TEMP_0_PIN 13 // ANALOG NUMBERING
#define TEMP_1_PIN 14 // ANALOG NUMBERING
#define TEMP_2_PIN 13 //15
it the same low blinking for heat, and i see a real temperature on 3 extruder
where there are other setup ?
thanks
but i think there are a bug in firmware!
in my configuration.h
i do that
i comment this two line
//#define EXT1_HEATER_PIN HEATER_2_PIN
//#define EXT2_HEATER_PIN HEATER_2_PIN
if you can find the bug...
In first time all heater and sensor is on heater 0 and temps sensor 0
Dont work !
In seconde time i change the pin for heater 2 the same of heater 0
Dont work!
Maybe for you is not a bug but for me it is
If i change the pin and it is not respected is a bug!
