Timelapse Start Command
I tried to look up this thing on the forums and documentation but failed so I assume it is not available.
I wanted to know if there was a possibility to start the recording only with a command, very similar to "Only at; @make_snapshot server command"
Example with "; @make_record" and using settings as per screen: https://prnt.sc/26er8lh
Thank you
  • Hello.
    Currently there is no way to start a timelapse recording while printing.
    This feature could be interesting though
