1.2.1 Version : Incorrect display for process time and wrong queue
Since the update to 1.2.1 an incorrect time calculation is displayed. If a file is started, the time bar immediately jumps to 25 to 30 percent. In addition, the currently printed file is automatically loaded into the queue.
  • File was always added to queue just was hidden. As you see in queue it marks it as being printed. We have added a count so you can say make x copies. To be able to change that during print we show it also while print, so that is normal.
    How long s the print time with wrong calculation? After start the heating bed/extruder time is removed directly. That is correct. In 1.2.1 the bar is now also showing time and not percent of lines printed. The difference between ete and percentage confused users so now both show same parameter reference.
