Slic3r not using Repetier parameters
in Slic3r
I've upgraded lately Host V2.2.2 and Slic3r 1.30 and now when I click on Slicer instead of using the Repetier selected files it launches the Slic3r window which defaults to totally different files. Also the location on the build plate is ignored and it always puts it in the center.
Previously that Slic3r dialog never showed up unless I clicked on Configuration. Why is Repetier using "Sic3r_settings.ini" when I have "Print Setting", "printer settings" and "Extruder-1" already set up in Repetier?
What do I need to do within Repetier to go back to the old way without launching the slic3r dialog box?
10:15:59.304 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "slic3r_settings.ini" --print-center 100.00,100.00 -o "composition.gcode" "composition.amf"
10:15:59.320 : Preferred name from WaveGen66-140T-0_5M-P1 to WaveGen66-140T-0_5M-P1
10:17:08.345 : <Slic3r> Slic3r installed in a loclized path. Using an 8.3 path: "C:\PROGRA~1\REPETI~1\Slic3r\"
You see while you had --print-center explaining the centering I had --dont-arrange so I guess in manager you have set version not to 1.3.0 or higher where the don't arrange option was added.
