Z-Hop and TimeLapse
Is it possible to have Repetier invoke a z-Hop when setting up for a time lapse layer change photo?
Moving the extruder "out of the way" is an opportunity for the hot-end to clip something and get a layer-shift... looking into other things as well, but the layer change photo is an obvious place to start...
  • Yes. It takes values from Printer config->Tools->General Extruder parameter and there is also a Z-Hop you can select.
