Setup - Raise3D E2 idex
Hi
I am very disappointed by the communications errors in my E2, it is almost impossible to print in vase mode without the infamous "pause problem"; Raise was enable to fix the problem until now and I am trying Repetier-server connected to the controller board.
I can use T0 (left one), but when I start using T1 (right one), the extruder heats up but don't move (T0 keeps moving instead of T1).
Also I am unable to home T1 in X.
Gcode is exported from ideamaker with usual settings.
Any suggestion?
Thank You
Any suggestion?
Thank You
Which g-codes are required for Raise3D to move the other extruder?
In server there is in G-Codes a replacement tab - there you can replace
T0 and T1 by several commands so they do what you need on that printer. All you need to do is add the commands that switch the axis.
In my limited knowledge, I thought the g-code was simply passed from the control board to the motion board, but looks like there is a sort of translation to adapt the code to the printer. My idex printer has a Duet-like board with RepRap firmware but I have no idea where to find the g-code that switch the axis, maybe I need only to change X g-code values with U... I'm afraid of doing damage...
GM
Printing great now
Thank you
GM
