Problems with z-height and layer display.
I am running repeater server 0.65.0 on Raspberry Pi2. Generally the software works great. I have noticed however some problems with layers and z-height display in both normal and LCD touch screen versions. In the print tab on LCD touch screen, when printing something, current layer information is displayed as either 0/0 or sometimes, if I get lucky, the current layer being printed out of zero layers (45/0). The Z-Position is also erratic. Sometimes it works as it should, sometimes it displays 200.00mm.
In the display accessible through web browser on the print tab when viewing uploaded g-codes in list mode the column Layer always shows 0 for all the files. Same in the popup window when I click on the info icon (little i). What is funny however, when clicking on the eye icon, the G-code preview section shows number of layers correctly. When going to the control tab while printing something the Z-position is also not working. X and Y positions are being shown correctly. Print job section in the control tab also displays incorrect information.
Is this a bug or some misconfiguration in my installation?
Regards,
yOOrek
; first_layer_height = [first_layer_height]
; layer height = [layer_height]
; perimeters = [perimeters]
; fill_density = [fill_density]
; fill_pattern = [fill_pattern]
; first_layer_bed_temperature = [first_layer_bed_temperature]
; bed_temperature = [bed_temperature]
; disable_fan_first_layers = [disable_fan_first_layers]
; Autolevel
G28 ; Home all axis
G4 P1000 ; Wait one second
M340 P0 S1500 ; pozycja pionowa czujnika autolevelingu
G32 ; Perform autolevel
M340 P0 S505 ; pozycja pozioma czujnika autolevelingu
G28 X0 ; Home X
M340 P0 S0 ; Turn off autolevel sensor
G28 Y0 ; Home Y
G92 E0 ; Reset extruder position to 0
G1 Z0.12 ; wartosc z kalibracji osi Z
G92 Z0 ; Reset Z axis to 0
; Ready to print
END G-CODE -
; End G-code
M104 S0 ; turn off temperature
M140 S0 ; Set bed temperature to 0
G28 X0 ; home X axis
G28 Z0 ; home Z axis
G1 Y170 ; move table forward
M84 ; disable motors
M42 P9 S0
BEFORE LAYER CHANGE -
; Start of layer [layer_num]
Repetier server event dependent g-code is defined only for 'Run if job is aborted'.
Hope you can access the link without any problems.
; End G-code
M42 P9 S0
; End G-code
M42 P9 S0
Then when the file is uploaded to the server the correct number of layers is displayed. Somehow my original code was tripping up the logic.
