I just built a Kossel mini using radds board, the max end stop doing good. Just wonder how to setup the probe Z with min Z end stop?
Do I need to set up the min Z end stop (pin no.) when downloading the repeiter firmware or modified the cong.h file after download?
Please help!
Thanks for your reply UniversalRemonster!
U mension "In the Z-Probe configuration you use Z_min for Z-Probe Pin. "
This is what i want to know!
Between when i type G29, there was no reaction!
Below is my config.h
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Well, there's a lot wrong with this configuration.h. First Z-Probe is disabled haha. Below, in red, are the correct settings you should use.
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_SPEED 5
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 5
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 -60
#define Z_PROBE_X2 -30
#define Z_PROBE_Y2 -60
#define Z_PROBE_X3 30
#define Z_PROBE_Y3 -60
I followed what u told me to update the config.h, but the probe Z crash on the glass, seems not working!
Will that be endstop setting problem?
#define min_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
