Something wrong in that Z LEVELING TUTORIAL https://www.youtube.com/watch?v=L9URtv2LqKc
I wonder why in this turorial :
they use G32 and G29.
In another post, you say that there is no need to use G29 because G32 is more efficient (http://forum.repetier.com/discussion/713/g29-crash-my-delta#latest).
Finally, what's the difference between G32 and G29 ?
Second question :
On my delta printer, G32 works fine but when I do :
- G32
- Mapping with Reptetier Host
- G28 (not in the video but necessary ?)
- G29
like in this tutorial, The G29 doesn't Works. The upper-left and upper-right probe points are out my bed (It probes a 7 by 7 matrix instead of 3 points with G32). I red in a post that normally, G32 and G29 should probe the same points.
Can you explain this strange behaviour ?
How can I change the coordonates of probed points with G29 ? Is it necessary ?
Version of Repetier firmware : 0.92.5
Thank you for your answers !
Second question :
- G32
- G29
